Beam Design - NM Covered Area
Grade: 24F-V8 1.8E DF/DF
Size: 5.5 x 19.5
Design Span (L): 20.54 ft.
Clear Span: 20.08 ft.
Total Span: 21.00 ft.
Bearing (lb): 5.5 in.
Selfweight: 542.6 lbs
Dist. Selfweight: 26.42 plf
Total Weight: 554.7 lbs
CL Beam Stability Factor 0.899 - - - - -
CV Volume Factor 0.948b - - - - -
Beam Design Joshua Milgram USA NM
9/15/2024 1
d = 19.500 in.
A = 5.500 x 19.500 = 107.25 in.2
Sx = (5.500)(19.500)2/6 = 348.56 in.3
Sy = (5.500)2(19.500)/6 = 98.31 in.3
Ix = (5.500)(19.500)3/12 = 3398.48 in.4
Iy = (5.500)3(19.500)/12 = 270.36 in.4
9/15/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [107.25 x (246.50 + 5.5)] x (12 in./ft.)3 = 15.64 ft3
Volumespan = N[A x L] = 1 x [107.25 x 246.50] x (12 in./ft.)3 = 15.30 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 15.64 = 554.7 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 15.30 = 542.6 lbs
Distributed Self Weight (ws) = = 26.42 plf
  ws = 26.42 plf
20.54 ft.
20.08 ft.
21.00 ft.
2114.90 lbs
2114.90 lbs
9/15/2024 3
lu = Unbraced Length = 20.542 ft.
lu/d = = 12.64
le = 1.63lu + 3d = 1.63(246.5) + 3(19.5) = 460.30 in. = 38.36 ft.  (NDS Table 3.3.3)
Rb = = 17.23
 Rb = 17.23 < 50   ➜  OK
9/15/2024 4
FbE = = 2863.48 psi
CL =   = 0.899
CV = = 0.948
CL = 0.899 < CV = 0.948
Fbx' = (2400)(1.15)(0.8)(1)(0.899) = 1984.1 psi
fb = = 365.8 psi
 fb = 365.8 psi < Fbx' = 1984.1 psi  (CSI = 0.18)   ➜  OK
fv* = = 24.36 psi
9/15/2024 5
 fv* = 24.36 psi < Fvx' = 266.66 psi  (CSI = 0.09)   ➜  OK
fv = = 28.93 psi
 fv = 28.93 psi < Fvx' = 266.66 psi  (CSI = 0.11)   ➜  OK
ΔLL = = 0.08 in.
(L/d)LL = 246.50 / 0.08 = 3135
 ΔLL = 0.08 in = L/3135 < L/360   ➜  OK
ΔTL = = 0.16 in.
(L/d)TL = 246.50 / 0.16 = 1557
 ΔTL = 0.16 in = L/1557 < L/240   ➜  OK
9/15/2024 6
fc⊥ = = 69.9 psi
 fc⊥ = 69.9 psi < Fc⊥x' = 344.50 psi  (CSI = 0.20)   ➜  OK
9/15/2024 7
