Design Span (L): 6.94 ft.
Clear Span: 6.48 ft.
Total Span: 7.40 ft.
Bearing (lb): 5.5 in.
Live Load: 853 plf
Dead Load: 92 plf
Selfweight: 71.2 lbs
Dist. Selfweight: 10.25 plf
Total Weight: 75.9 lbs
Beam Design 2024A396
9/6/2024 1
9/6/2024 2
Volumetotal = N[A x (L + lb)] = 3 x [13.88 x (83.30 + 5.5)] x (12 in./ft.)3 = 2.14 ft3
Volumespan = N[A x L] = 3 x [13.88 x 83.30] x (12 in./ft.)3 = 2.01 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 2.14 = 75.9 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 2.01 = 71.2 lbs
Distributed Self Weight (ws) = = 10.25 plf
853 plf
92 plf
ws = 10.25 plf
6.94 ft.
6.48 ft.
7.40 ft.
3534.59 lbs
3534.59 lbs
9/6/2024 3
fb = = 1076.1 psi
 fb = 1076.1 psi < Fbx' = 1138.5 psi  (CSI = 0.95)   ➜  OK
9/6/2024 4
fv* = = 92.95 psi
 fv* = 92.95 psi < Fvx' = 200.79 psi  (CSI = 0.46)   ➜  OK
fv = = 119.48 psi
 fv = 119.48 psi < Fvx' = 200.79 psi  (CSI = 0.60)   ➜  OK
9/6/2024 5
ΔLL = = 0.10 in.
(L/d)LL = 83.30 / 0.10 = 799
 ΔLL = 0.10 in = L/799 < L/240   ➜  OK
ΔTL = = 0.12 in.
(L/d)TL = 83.30 / 0.12 = 713
 ΔTL = 0.12 in = L/713 < L/180   ➜  OK
fc⊥ = = 142.8 psi
 fc⊥ = 142.8 psi < Fc⊥x' = 418.75 psi  (CSI = 0.34)   ➜  OK
9/6/2024 6
