Design Span (L): 6.94 ft.
Clear Span: 6.48 ft.
Total Span: 7.40 ft.
Bearing (lb): 5.5 in.
Live Load: 853 plf
Dead Load: 92 plf
Selfweight: 47.4 lbs
Dist. Selfweight: 6.83 plf
Total Weight: 50.6 lbs
Beam Design 2024A395
9/6/2024 1
9/6/2024 2
Volumetotal = N[A x (L + lb)] = 2 x [13.88 x (83.30 + 5.5)] x (12 in./ft.)3 = 1.43 ft3
Volumespan = N[A x L] = 2 x [13.88 x 83.30] x (12 in./ft.)3 = 1.34 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 1.43 = 50.6 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 1.34 = 47.4 lbs
Distributed Self Weight (ws) = = 6.83 plf
853 plf
92 plf
ws = 6.83 plf
6.94 ft.
6.48 ft.
7.40 ft.
3521.95 lbs
3521.95 lbs
9/6/2024 3
fb = = 1608.3 psi
 fb = 1608.3 psi > Fbx' = 1138.5 psi  (CSI = 1.41)   ➜  NG
9/6/2024 4
fv* = = 138.93 psi
 fv* = 138.93 psi < Fvx' = 200.79 psi  (CSI = 0.69)   ➜  OK
fv = = 178.58 psi
 fv = 178.58 psi < Fvx' = 200.79 psi  (CSI = 0.89)   ➜  OK
9/6/2024 5
ΔLL = = 0.16 in.
(L/d)LL = 83.30 / 0.16 = 533
 ΔLL = 0.16 in = L/533 < L/240   ➜  OK
ΔTL = = 0.17 in.
(L/d)TL = 83.30 / 0.17 = 477
 ΔTL = 0.17 in = L/477 < L/180   ➜  OK
fc⊥ = = 213.5 psi
 fc⊥ = 213.5 psi < Fc⊥x' = 418.75 psi  (CSI = 0.51)   ➜  OK
9/6/2024 6
