Design Span (L): 6.94 ft.
Clear Span: 6.48 ft.
Total Span: 7.40 ft.
Bearing (lb): 5.5 in.
Live Load: 853 plf
Dead Load: 92 plf
Selfweight: 37.2 lbs
Dist. Selfweight: 5.36 plf
Total Weight: 39.6 lbs
Beam Design 2024A392
9/6/2024 1
9/6/2024 2
Volumetotal = N[A x (L + lb)] = 2 x [10.88 x (83.30 + 5.5)] x (12 in./ft.)3 = 1.12 ft3
Volumespan = N[A x L] = 2 x [10.88 x 83.30] x (12 in./ft.)3 = 1.05 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 1.12 = 39.6 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 1.05 = 37.2 lbs
Distributed Self Weight (ws) = = 5.36 plf
853 plf
92 plf
ws = 5.36 plf
6.94 ft.
6.48 ft.
7.40 ft.
3516.48 lbs
3516.48 lbs
9/6/2024 3
fb = = 2614.0 psi
 fb = 2614.0 psi > Fbx' = 1242.0 psi  (CSI = 2.10)   ➜  NG
9/6/2024 4
fv* = = 187.90 psi
 fv* = 187.90 psi < Fvx' = 200.79 psi  (CSI = 0.94)   ➜  OK
fv = = 227.50 psi
 fv = 227.50 psi > Fvx' = 200.79 psi  (CSI = 1.13)   ➜  NG
9/6/2024 5
ΔLL = = 0.32 in.
(L/d)LL = 83.30 / 0.32 = 256
 ΔLL = 0.32 in = L/256 < L/240   ➜  OK
ΔTL = = 0.36 in.
(L/d)TL = 83.30 / 0.36 = 230
 ΔTL = 0.36 in = L/230 < L/180   ➜  OK
fc⊥ = = 213.1 psi
 fc⊥ = 213.1 psi < Fc⊥x' = 418.75 psi  (CSI = 0.51)   ➜  OK
9/6/2024 6
