Beam Design - Wall Reconfiguration
Size: 3.5 x 9
Design Span (L): 18.62 ft.
Clear Span: 18.41 ft.
Total Span: 18.83 ft.
Bearing (lb): 2.5 in.
Selfweight: 137.5 lbs
Dist. Selfweight: 7.39 plf
Total Weight: 139.1 lbs
Beam Design Linda Haong 2631 Loganrita, Arcadia, CA 005
9/6/2024 1
d = 9.000 in.
9/6/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [31.50 x (223.46 + 2.5)] x (12 in./ft.)3 = 4.12 ft3
Volumespan = N[A x L] = 1 x [31.50 x 223.46] x (12 in./ft.)3 = 4.07 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 4.12 = 139.1 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 4.07 = 137.5 lbs
  ws = 7.39 plf
18.62 ft.
18.41 ft.
18.83 ft.
1717.19 lbs
1717.19 lbs
9/6/2024 3
Fbx' = (2400)(1.00)(1)(0.8)(1.0) = 1920.0 psi
fb = = 2007.9 psi
 fb = 2007.9 psi > Fbx' = 1920.0 psi  (CSI = 1.05)   ➜  NG
9/6/2024 4
Fvx' = (265)(1.00)(1)(0.8) = 212.00 psi
fv* = = 74.35 psi
 fv* = 74.35 psi < Fvx' = 212.00 psi  (CSI = 0.35)   ➜  OK
fv = = 80.87 psi
 fv = 80.87 psi < Fvx' = 212.00 psi  (CSI = 0.38)   ➜  OK
9/6/2024 5
ΔLL = = 0.79 in.
(L/d)LL = 223.46 / 0.79 = 284
 ΔLL = 0.79 in = L/284 > L/360   ➜  NG
ΔTL = = 1.43 in.
(L/d)TL = 223.46 / 1.43 = 156
 ΔTL = 1.43 in = L/156 > L/240   ➜  NG
Ab = b x lb = 3.5 x 2.5 = 8.75 in2
fc⊥ = = 196.3 psi
 fc⊥ = 196.3 psi < Fc⊥x' = 520.00 psi  (CSI = 0.38)   ➜  OK
9/6/2024 6
