Size: 5.5 x 12
Design Span (L): 15.75 ft.
Clear Span: 15.50 ft.
Total Span: 16.00 ft.
Live Load: 390 plf
Dead Load: 97.5 plf
Selfweight: 243.7 lbs
Dist. Selfweight: 15.47 plf
Total Weight: 247.6 lbs
Beam Design 2024A387
9/6/2024 1
9/6/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [66.00 x (189.00 + 3)] x (12 in./ft.)3 = 7.33 ft3
Volumespan = N[A x L] = 1 x [66.00 x 189.00] x (12 in./ft.)3 = 7.22 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 7.33 = 247.6 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 7.22 = 243.7 lbs
390 plf
97.5 plf
  ws = 15.47 plf
15.75 ft.
15.50 ft.
4023.79 lbs
4023.79 lbs
9/6/2024 3
fb = = 1417.8 psi
 fb = 1417.8 psi < Fbx' = 2760.0 psi  (CSI = 0.51)   ➜  OK
9/6/2024 4
fv* = = 78.59 psi
 fv* = 78.59 psi < Fvx' = 304.75 psi  (CSI = 0.26)   ➜  OK
fv = = 90.02 psi
 fv = 90.02 psi < Fvx' = 304.75 psi  (CSI = 0.30)   ➜  OK
9/6/2024 5
ΔLL = = 0.38 in.
(L/d)LL = 189.00 / 0.38 = 499
 ΔLL = 0.38 in = L/499 < L/360   ➜  OK
ΔTL = = 0.49 in.
(L/d)TL = 189.00 / 0.49 = 387
 ΔTL = 0.49 in = L/387 < L/240   ➜  OK
fc⊥ = = 243.9 psi
 fc⊥ = 243.9 psi < Fc⊥x' = 650.00 psi  (CSI = 0.38)   ➜  OK
9/6/2024 6
