Beam Design - BEAM 1 (JOIST)
Grade: SPF No.2
Design Span (L): 8.38 ft.
Clear Span: 8.25 ft.
Total Span: 8.50 ft.
Bearing (lb): 1.5 in.
Dead Load: 18 plf
Selfweight: 24.5 lbs
Dist. Selfweight: 2.92 plf
Total Weight: 24.8 lbs
Lateral Support: 8' o/c
CL Beam Stability Factor 0.609 - - - - -
Beam Design NAIMA 2
9/5/2024 1
Beam Design NAIMA 2
9/5/2024 2
= 30.34 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (100.50 + 1.5)] x (12 in./ft.)3 = 0.82 ft3
Volumespan = N[A x L] = 1 x [13.88 x 100.50] x (12 in./ft.)3 = 0.81 ft3
Total Weight (WT) = ρw x Volumetotal = 30.34 x 0.82 = 24.8 lbs
Self Weight (WS) = ρw x Volumespan = 30.34 x 0.81 = 24.5 lbs
Distributed Self Weight (ws) = = 2.92 plf
18 plf
ws = 2.92 plf
8.38 ft.
8.25 ft.
8.50 ft.
513.92 lbs
513.92 lbs
Beam Design NAIMA 2
9/5/2024 3
lu = Unbraced Length = 8 ft.
lu/d = = 10.38
le = 1.63lu + 3d = 1.63(96.0) + 3(9.25) = 184.23 in. = 15.35 ft.  (NDS Table 3.3.3)
Rb = = 27.52
 Rb = 27.52 < 50   ➜  OK
Beam Design NAIMA 2
9/5/2024 4
Eminy' = Eminy(CM)(Ct)(Ci) = 510000(0.9)(1)(1) = 459000 psi
FbE = = 727.23 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (875)(1.00)(1)(1)(1.1)(1)(1.15) = 1106.88 psi
CL =   = 0.609
Fbx' = (875)(1.00)(1)(1)(0.609)(1.1)(1)(1.15) = 674.6 psi
fb = = 594.8 psi
 fb = 594.8 psi < Fbx' = 674.6 psi  (CSI = 0.88)   ➜  OK
Fvx' = (135)(1.00)(0.97)(1)(1) = 130.95 psi
fv* = = 44.67 psi
 fv* = 44.67 psi < Fvx' = 130.95 psi  (CSI = 0.34)   ➜  OK
fv = = 54.74 psi
 fv = 54.74 psi < Fvx' = 130.95 psi  (CSI = 0.42)   ➜  OK
Beam Design NAIMA 2
9/5/2024 5
ΔLL = = 0.09 in.
(L/d)LL = 100.50 / 0.09 = 1132
 ΔLL = 0.09 in = L/1132 < L/360   ➜  OK
ΔTL = = 0.11 in.
(L/d)TL = 100.50 / 0.11 = 936
 ΔTL = 0.11 in = L/936 < L/240   ➜  OK
fc⊥ = = 228.4 psi
 fc⊥ = 228.4 psi < Fc⊥x' = 284.75 psi  (CSI = 0.80)   ➜  OK
Beam Design NAIMA 2
9/5/2024 6
