Design Span (L): 10.75 ft.
Clear Span: 10.50 ft.
Total Span: 11.00 ft.
Live Load: 8000 lbs
Dead Load: 0 lbs
Selfweight: 129.3 lbs
Dist. Selfweight: 12.02 plf
Total Weight: 132.3 lbs
CL Beam Stability Factor 0.990 - - - - -
Beam Design 2024A380
9/3/2024 1
9/3/2024 2
Volumetotal = N[A x (L + lb)] = 3 x [16.88 x (129.00 + 3)] x (12 in./ft.)3 = 3.87 ft3
Volumespan = N[A x L] = 3 x [16.88 x 129.00] x (12 in./ft.)3 = 3.78 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 3.87 = 132.3 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 3.78 = 129.3 lbs
8000 lbs
0 lbs
ws = 12.02 plf
10.75 ft.
10.50 ft.
11.00 ft.
4066.14 lbs
4066.14 lbs
9/3/2024 3
lu = Unbraced Length = 10.750 ft.
lu/d = = 11.47
le = 1.37lu + 3d = 1.37(129.0) + 3(11.25) = 210.48 in. = 17.54 ft.  (NDS Table 3.3.3)
Rb = = 10.81
 Rb = 10.81 < 50   ➜  OK
9/3/2024 4
FbE = = 5952.11 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (900)(1.15)(1)(1)(1)(1)(1) = 1035.00 psi
CL =   = 0.990
Fbx' = (900)(1.15)(1)(1)(0.990)(1)(1)(1) = 1024.4 psi
fb = = 2740.0 psi
 fb = 2740.0 psi > Fbx' = 1024.4 psi  (CSI = 2.67)   ➜  NG
fv* = = 120.10 psi
 fv* = 120.10 psi < Fvx' = 207.00 psi  (CSI = 0.58)   ➜  OK
fv = = 120.43 psi
 fv = 120.43 psi < Fvx' = 207.00 psi  (CSI = 0.58)   ➜  OK
9/3/2024 5
ΔLL =   =   = 0.42 in.
(L/d)LL = 129.00 / 0.42 = 308
 ΔLL = 0.42 in = L/308 > L/360   ➜  NG
ΔTL =   =   = 0.42 in.
(L/d)TL = 129.00 / 0.42 = 305
 ΔTL = 0.42 in = L/305 < L/240   ➜  OK
fc⊥ = = 301.2 psi
 fc⊥ = 301.2 psi < Fc⊥x' = 625.00 psi  (CSI = 0.48)   ➜  OK
9/3/2024 6
