Beam Design - Porch
Size: 5.5 x 10.5
Design Span (L): 15.25 ft.
Clear Span: 15.00 ft.
Total Span: 15.50 ft.
Live Load: 35 plf
Dead Load: 15 plf
Selfweight: 206.5 lbs
Dist. Selfweight: 13.54 plf
Total Weight: 209.9 lbs
Notes: Performing check to my hand calcs
Beam Design E Cr Colorado 001
8/26/2024 1
d = 10.500 in.
A = 5.500 x 10.500 = 57.75 in.2
Sx = (5.500)(10.500)2/6 = 101.06 in.3
Sy = (5.500)2(10.500)/6 = 52.94 in.3
Ix = (5.500)(10.500)3/12 = 530.58 in.4
Iy = (5.500)3(10.500)/12 = 145.58 in.4
8/26/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [57.75 x (183.00 + 3)] x (12 in./ft.)3 = 6.22 ft3
Volumespan = N[A x L] = 1 x [57.75 x 183.00] x (12 in./ft.)3 = 6.12 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 6.22 = 209.9 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 6.12 = 206.5 lbs
35 plf
15 plf
  ws = 13.54 plf
15.25 ft.
15.00 ft.
15.50 ft.
492.43 lbs
492.43 lbs
8/26/2024 3
fb = = 219.3 psi
 fb = 219.3 psi < Fbx' = 2760.0 psi  (CSI = 0.08)   ➜  OK
8/26/2024 4
fv* = = 11.14 psi
 fv* = 11.14 psi < Fvx' = 304.75 psi  (CSI = 0.04)   ➜  OK
fv = = 12.58 psi
 fv = 12.58 psi < Fvx' = 304.75 psi  (CSI = 0.04)   ➜  OK
8/26/2024 5
ΔLL = = 0.04 in.
(L/d)LL = 183.00 / 0.04 = 4103
 ΔLL = 0.04 in = L/4103 < L/360   ➜  OK
ΔTL = = 0.08 in.
(L/d)TL = 183.00 / 0.08 = 2260
 ΔTL = 0.08 in = L/2260 < L/240   ➜  OK
fc⊥ = = 29.8 psi
 fc⊥ = 29.8 psi < Fc⊥x' = 650.00 psi  (CSI = 0.05)   ➜  OK
8/26/2024 6
