Design Span (L): 8.08 ft.
Clear Span: 7.83 ft.
Total Span: 8.33 ft.
Selfweight: 30.0 lbs
Dist. Selfweight: 3.72 plf
Total Weight: 31.0 lbs
Beam Design 2024A362
8/23/2024 1
8/23/2024 2
= 38.58 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (96.96 + 3)] x (12 in./ft.)3 = 0.80 ft3
Volumespan = N[A x L] = 1 x [13.88 x 96.96] x (12 in./ft.)3 = 0.78 ft3
Total Weight (WT) = ρw x Volumetotal = 38.58 x 0.80 = 31.0 lbs
Self Weight (WS) = ρw x Volumespan = 38.58 x 0.78 = 30.0 lbs
Distributed Self Weight (ws) = = 3.72 plf
ws = 3.72 plf
8.08 ft.
7.83 ft.
8.33 ft.
744.36 lbs
744.36 lbs
8/23/2024 3
Fbx' = (800)(1.00)(1)(1)(1)(1)(1)(1) = 800.0 psi
fb = = 818.2 psi
 fb = 818.2 psi > Fbx' = 800.0 psi  (CSI = 1.02)   ➜  NG
8/23/2024 4
fv* = = 63.16 psi
 fv* = 63.16 psi < Fvx' = 169.75 psi  (CSI = 0.37)   ➜  OK
fv = = 78.06 psi
 fv = 78.06 psi < Fvx' = 169.75 psi  (CSI = 0.46)   ➜  OK
8/23/2024 5
ΔLL = = 0.08 in.
(L/d)LL = 96.96 / 0.08 = 1260
 ΔLL = 0.08 in = L/1260 < L/360   ➜  OK
ΔTL = = 0.14 in.
(L/d)TL = 96.96 / 0.14 = 705
 ΔTL = 0.14 in = L/705 < L/240   ➜  OK
fc⊥ = = 165.4 psi
 fc⊥ = 165.4 psi < Fc⊥x' = 378.55 psi  (CSI = 0.44)   ➜  OK
8/23/2024 6
