Design Span (L): 7.75 ft.
Clear Span: 7.50 ft.
Total Span: 8.00 ft.
Live Load: 418 plf
Dead Load: 112 plf
Selfweight: 67.8 lbs
Dist. Selfweight: 8.75 plf
Total Weight: 70.0 lbs
Beam Design Nierman 2024A360
8/20/2024 1
8/20/2024 2
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.88 = 70.0 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.82 = 67.8 lbs
418 plf
112 plf
ws = 8.75 plf
7.75 ft.
7.50 ft.
2155.00 lbs
2155.00 lbs
8/20/2024 3
fb = = 767.0 psi
 fb = 767.0 psi < Fbx' = 862.5 psi  (CSI = 0.89)   ➜  OK
8/20/2024 4
fv* = = 70.34 psi
 fv* = 70.34 psi < Fvx' = 201.25 psi  (CSI = 0.35)   ➜  OK
fv = = 92.78 psi
 fv = 92.78 psi < Fvx' = 201.25 psi  (CSI = 0.46)   ➜  OK
8/20/2024 5
ΔLL = = 0.07 in.
(L/d)LL = 93.00 / 0.07 = 1366
 ΔLL = 0.07 in = L/1366 < L/180   ➜  OK
ΔTL = = 0.09 in.
(L/d)TL = 93.00 / 0.09 = 1060
 ΔTL = 0.09 in = L/1060 < L/120   ➜  OK
fc⊥ = = 239.4 psi
 fc⊥ = 239.4 psi < Fc⊥x' = 565.00 psi  (CSI = 0.42)   ➜  OK
8/20/2024 6
