Beam Design - Sunroom
Size: 3.125 x 9
Design Span (L): 7.25 ft.
Clear Span: 7.00 ft.
Total Span: 7.50 ft.
Selfweight: 47.8 lbs
Dist. Selfweight: 6.59 plf
Total Weight: 49.5 lbs
Beam Design Jeff Boyne 2024A36
1/29/2024 1
b = 3.125 in.
d = 9.000 in.
A = 3.125 x 9.000 = 28.13 in.2
Sx = (3.125)(9.000)2/6 = 42.19 in.3
Sy = (3.125)2(9.000)/6 = 14.65 in.3
Ix = (3.125)(9.000)3/12 = 189.84 in.4
Iy = (3.125)3(9.000)/12 = 22.89 in.4
1/29/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [28.13 x (87.00 + 3)] x (12 in./ft.)3 = 1.46 ft3
Volumespan = N[A x L] = 1 x [28.13 x 87.00] x (12 in./ft.)3 = 1.42 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 1.46 = 49.5 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 1.42 = 47.8 lbs
  ws = 6.59 plf
7.25 ft.
7.00 ft.
7.50 ft.
680.98 lbs
680.98 lbs
1/29/2024 3
fb = = 339.4 psi
 fb = 339.4 psi < Fbx' = 2760.0 psi  (CSI = 0.12)   ➜  OK
1/29/2024 4
fv* = = 27.84 psi
 fv* = 27.84 psi < Fvx' = 304.75 psi  (CSI = 0.09)   ➜  OK
fv = = 35.11 psi
 fv = 35.11 psi < Fvx' = 304.75 psi  (CSI = 0.12)   ➜  OK
1/29/2024 5
ΔLL = = 0.02 in.
(L/d)LL = 87.00 / 0.02 = 4782
 ΔLL = 0.02 in = L/4782 < L/360   ➜  OK
ΔTL = = 0.03 in.
(L/d)TL = 87.00 / 0.03 = 2634
 ΔTL = 0.03 in = L/2634 < L/240   ➜  OK
fc⊥ = = 72.6 psi
 fc⊥ = 72.6 psi < Fc⊥x' = 650.00 psi  (CSI = 0.11)   ➜  OK
1/29/2024 6
