Size: 6.75 x 10.5
Design Span (L): 20.25 ft.
Clear Span: 20.00 ft.
Total Span: 20.50 ft.
Selfweight: 336.5 lbs
Dist. Selfweight: 16.62 plf
Total Weight: 340.6 lbs
CV Volume Factor 0.990b - - - - -
Beam Design 1000
8/20/2024 1
b = 6.750 in.
d = 10.500 in.
A = 6.750 x 10.500 = 70.88 in.2
Sx = (6.750)(10.500)2/6 = 124.03 in.3
Sy = (6.750)2(10.500)/6 = 79.73 in.3
Ix = (6.750)(10.500)3/12 = 651.16 in.4
Iy = (6.750)3(10.500)/12 = 269.10 in.4
Beam Design 1000
8/20/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [70.88 x (243.00 + 3)] x (12 in./ft.)3 = 10.09 ft3
Volumespan = N[A x L] = 1 x [70.88 x 243.00] x (12 in./ft.)3 = 9.97 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 10.09 = 340.6 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 9.97 = 336.5 lbs
Distributed Self Weight (ws) = = 16.62 plf
  ws = 16.62 plf
20.25 ft.
20.50 ft.
1964.07 lbs
1964.07 lbs
Beam Design 1000
8/20/2024 3
CV = = 0.990
CV = 0.990 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.990) = 2731.0 psi
fb = = 950.3 psi
 fb = 950.3 psi < Fbx' = 2731.0 psi  (CSI = 0.35)   ➜  OK
Beam Design 1000
8/20/2024 4
fv* = = 37.51 psi
 fv* = 37.51 psi < Fvx' = 304.75 psi  (CSI = 0.12)   ➜  OK
fv = = 41.06 psi
 fv = 41.06 psi < Fvx' = 304.75 psi  (CSI = 0.13)   ➜  OK
Beam Design 1000
8/20/2024 5
ΔLL = = 0.32 in.
(L/d)LL = 243.00 / 0.32 = 753
 ΔLL = 0.32 in = L/753 < L/360   ➜  OK
ΔTL = = 0.62 in.
(L/d)TL = 243.00 / 0.62 = 393
 ΔTL = 0.62 in = L/393 < L/240   ➜  OK
fc⊥ = = 97.0 psi
 fc⊥ = 97.0 psi < Fc⊥x' = 650.00 psi  (CSI = 0.15)   ➜  OK
Beam Design 1000
8/20/2024 6
