Species: Alaska Yellow Cedar
Grade: AYC No.2
Design Span (L): 7.75 ft.
Clear Span: 7.50 ft.
Total Span: 8.00 ft.
Live Load: 560 plf
Dead Load: 140 plf
Selfweight: 37.1 lbs
Dist. Selfweight: 4.78 plf
Total Weight: 38.3 lbs
Beam Design 2024A353
8/13/2024 1
AYC No.2 800 450 225 510 1000 1300000 470000 0.46
G = 0.46
8/13/2024 2
= 31.67 lbs/ft3
Volumetotal = N[A x (L + lb)] = 2 x [10.88 x (93.00 + 3)] x (12 in./ft.)3 = 1.21 ft3
Volumespan = N[A x L] = 2 x [10.88 x 93.00] x (12 in./ft.)3 = 1.17 ft3
Total Weight (WT) = ρw x Volumetotal = 31.67 x 1.21 = 38.3 lbs
Self Weight (WS) = ρw x Volumespan = 31.67 x 1.17 = 37.1 lbs
Distributed Self Weight (ws) = = 4.78 plf
560 plf
140 plf
ws = 4.78 plf
7.75 ft.
7.50 ft.
2819.13 lbs
2819.13 lbs
8/13/2024 3
Fbx' = (800)(1.15)(1)(1)(1)(1.2)(1)(1) = 1104.0 psi
fb = = 2416.0 psi
 fb = 2416.0 psi > Fbx' = 1104.0 psi  (CSI = 2.19)   ➜  NG
8/13/2024 4
Fvx' = (225)(1.15)(1)(1)(1) = 258.75 psi
fv* = = 158.98 psi
 fv* = 158.98 psi < Fvx' = 258.75 psi  (CSI = 0.61)   ➜  OK
fv = = 188.35 psi
 fv = 188.35 psi < Fvx' = 258.75 psi  (CSI = 0.73)   ➜  OK
8/13/2024 5
ΔLL = = 0.37 in.
(L/d)LL = 93.00 / 0.37 = 253
 ΔLL = 0.37 in = L/253 > L/360   ➜  NG
ΔTL = = 0.46 in.
(L/d)TL = 93.00 / 0.46 = 201
 ΔTL = 0.46 in = L/201 > L/240   ➜  NG
Fc⊥x' = (510)(1)(1)(1) = 510.00 psi
fc⊥ = = 313.2 psi
 fc⊥ = 313.2 psi < Fc⊥x' = 510.00 psi  (CSI = 0.61)   ➜  OK
8/13/2024 6
