Beam Design - Beam Design 3 1/8 x 10 1/2 GLULAM
Size: 3.125 x 10.5
Design Span (L): 15.46 ft.
Clear Span: 15.08 ft.
Total Span: 15.83 ft.
Bearing (lb): 4.5 in.
Dead Load: 100 plf
Selfweight: 118.9 lbs
Dist. Selfweight: 7.69 plf
Total Weight: 121.8 lbs
Beam Design Kerry Boyle ABQ 1
8/11/2024 1
b = 3.125 in.
d = 10.500 in.
A = 3.125 x 10.500 = 32.81 in.2
Sx = (3.125)(10.500)2/6 = 57.42 in.3
Sy = (3.125)2(10.500)/6 = 17.09 in.3
Ix = (3.125)(10.500)3/12 = 301.46 in.4
Iy = (3.125)3(10.500)/12 = 26.70 in.4
8/11/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [32.81 x (185.46 + 4.5)] x (12 in./ft.)3 = 3.61 ft3
Volumespan = N[A x L] = 1 x [32.81 x 185.46] x (12 in./ft.)3 = 3.52 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 3.61 = 121.8 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 3.52 = 118.9 lbs
  ws = 7.69 plf
15.46 ft.
15.08 ft.
15.83 ft.
1643.89 lbs
1643.89 lbs
8/11/2024 3
fb = = 1295.9 psi
 fb = 1295.9 psi < Fbx' = 2760.0 psi  (CSI = 0.47)   ➜  OK
8/11/2024 4
fv* = = 65.06 psi
 fv* = 65.06 psi < Fvx' = 304.75 psi  (CSI = 0.21)   ➜  OK
fv = = 73.37 psi
 fv = 73.37 psi < Fvx' = 304.75 psi  (CSI = 0.24)   ➜  OK
8/11/2024 5
ΔLL = = 0.24 in.
(L/d)LL = 185.46 / 0.24 = 784
 ΔLL = 0.24 in = L/784 < L/360   ➜  OK
ΔTL = = 0.49 in.
(L/d)TL = 185.46 / 0.49 = 377
 ΔTL = 0.49 in = L/377 < L/240   ➜  OK
Ab = b x lb = 3.125 x 4.5 = 14.06 in2
fc⊥ = = 116.9 psi
 fc⊥ = 116.9 psi < Fc⊥x' = 650.00 psi  (CSI = 0.18)   ➜  OK
8/11/2024 6
