Beam Design - Back bedroom
Design Span (L): 3.92 ft.
Clear Span: 3.67 ft.
Total Span: 4.17 ft.
Live Load: 444 plf
Dead Load: 145 plf
Selfweight: 15.3 lbs
Dist. Selfweight: 3.92 plf
Total Weight: 16.3 lbs
Beam Design 1255 Cove
8/7/2024 1
8/7/2024 2
Volumetotal = N[A x (L + lb)] = 2 x [8.25 x (46.99 + 3)] x (12 in./ft.)3 = 0.48 ft3
Volumespan = N[A x L] = 2 x [8.25 x 46.99] x (12 in./ft.)3 = 0.45 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.48 = 16.3 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.45 = 15.3 lbs
444 plf
145 plf
ws = 3.92 plf
3.92 ft.
3.67 ft.
4.17 ft.
1235.05 lbs
1235.05 lbs
8/7/2024 3
fb = = 901.7 psi
 fb = 901.7 psi < Fbx' = 1345.5 psi  (CSI = 0.67)   ➜  OK
8/7/2024 4
fv* = = 80.83 psi
 fv* = 80.83 psi < Fvx' = 207.00 psi  (CSI = 0.39)   ➜  OK
fv = = 105.54 psi
 fv = 105.54 psi < Fvx' = 207.00 psi  (CSI = 0.51)   ➜  OK
8/7/2024 5
ΔLL = = 0.04 in.
(L/d)LL = 46.99 / 0.04 = 1331
 ΔLL = 0.04 in = L/1331 < L/180   ➜  OK
ΔTL = = 0.05 in.
(L/d)TL = 46.99 / 0.05 = 997
 ΔTL = 0.05 in = L/997 < L/120   ➜  OK
fc⊥ = = 137.2 psi
 fc⊥ = 137.2 psi < Fc⊥x' = 625.00 psi  (CSI = 0.22)   ➜  OK
8/7/2024 6
