Beam Design - Back bedroom
Design Span (L): 10.25 ft.
Clear Span: 10.00 ft.
Total Span: 10.50 ft.
Live Load: 444 plf
Dead Load: 145 plf
Selfweight: 123.3 lbs
Dist. Selfweight: 12.02 plf
Total Weight: 126.3 lbs
Beam Design 1255 Cove
8/7/2024 1
8/7/2024 2
Volumetotal = N[A x (L + lb)] = 3 x [16.88 x (123.00 + 3)] x (12 in./ft.)3 = 3.69 ft3
Volumespan = N[A x L] = 3 x [16.88 x 123.00] x (12 in./ft.)3 = 3.60 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 3.69 = 126.3 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 3.60 = 123.3 lbs
444 plf
145 plf
ws = 12.02 plf
10.25 ft.
10.00 ft.
10.50 ft.
3155.38 lbs
3155.38 lbs
8/7/2024 3
fb = = 997.8 psi
 fb = 997.8 psi < Fbx' = 1035.0 psi  (CSI = 0.96)   ➜  OK
8/7/2024 4
fv* = = 74.57 psi
 fv* = 74.57 psi < Fvx' = 207.00 psi  (CSI = 0.36)   ➜  OK
fv = = 91.27 psi
 fv = 91.27 psi < Fvx' = 207.00 psi  (CSI = 0.44)   ➜  OK
8/7/2024 5
ΔLL = = 0.13 in.
(L/d)LL = 123.00 / 0.13 = 953
 ΔLL = 0.13 in = L/953 < L/180   ➜  OK
ΔTL = = 0.17 in.
(L/d)TL = 123.00 / 0.17 = 704
 ΔTL = 0.17 in = L/704 < L/120   ➜  OK
fc⊥ = = 233.7 psi
 fc⊥ = 233.7 psi < Fc⊥x' = 625.00 psi  (CSI = 0.37)   ➜  OK
8/7/2024 6
