Size: 3.125 x 9
Selfweight: 77.5 lbs
Dist. Selfweight: 6.59 plf
Total Weight: 79.1 lbs
Beam Design 2024A34
1/29/2024 1
b = 3.125 in.
d = 9.000 in.
A = 3.125 x 9.000 = 28.13 in.2
Sx = (3.125)(9.000)2/6 = 42.19 in.3
Sy = (3.125)2(9.000)/6 = 14.65 in.3
Ix = (3.125)(9.000)3/12 = 189.84 in.4
Iy = (3.125)3(9.000)/12 = 22.89 in.4
Beam Design 2024A34
1/29/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [28.13 x (141.00 + 3)] x (12 in./ft.)3 = 2.34 ft3
Volumespan = N[A x L] = 1 x [28.13 x 141.00] x (12 in./ft.)3 = 2.29 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 2.34 = 79.1 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 2.29 = 77.5 lbs
  ws = 6.59 plf
1089.56 lbs
1089.56 lbs
Beam Design 2024A34
1/29/2024 3
fb = = 891.4 psi
 fb = 891.4 psi < Fbx' = 2760.0 psi  (CSI = 0.32)   ➜  OK
Beam Design 2024A34
1/29/2024 4
fv* = = 49.64 psi
 fv* = 49.64 psi < Fvx' = 304.75 psi  (CSI = 0.16)   ➜  OK
fv = = 56.90 psi
 fv = 56.90 psi < Fvx' = 304.75 psi  (CSI = 0.19)   ➜  OK
Beam Design 2024A34
1/29/2024 5
ΔLL = = 0.13 in.
(L/d)LL = 141.00 / 0.13 = 1123
 ΔLL = 0.13 in = L/1123 < L/360   ➜  OK
ΔTL = = 0.23 in.
(L/d)TL = 141.00 / 0.23 = 619
 ΔTL = 0.23 in = L/619 < L/240   ➜  OK
fc⊥ = = 116.2 psi
 fc⊥ = 116.2 psi < Fc⊥x' = 650.00 psi  (CSI = 0.18)   ➜  OK
Beam Design 2024A34
1/29/2024 6
