Size: 5.125 x 12
Design Span (L): 16.04 ft.
Clear Span: 15.58 ft.
Total Span: 16.50 ft.
Bearing (lb): 5.5 in.
Dead Load: 492 plf
Selfweight: 231.3 lbs
Dist. Selfweight: 14.42 plf
Total Weight: 237.9 lbs
Beam Design 12402 E CALLE ENTRADA Meza
8/6/2024 1
b = 5.125 in.
8/6/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [61.50 x (192.50 + 5.5)] x (12 in./ft.)3 = 7.05 ft3
Volumespan = N[A x L] = 1 x [61.50 x 192.50] x (12 in./ft.)3 = 6.85 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 7.05 = 237.9 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 6.85 = 231.3 lbs
492 plf
  ws = 14.42 plf
16.04 ft.
15.58 ft.
16.50 ft.
5003.06 lbs
5003.06 lbs
8/6/2024 3
fb = = 1903.2 psi
 fb = 1903.2 psi < Fbx' = 2400.0 psi  (CSI = 0.79)   ➜  OK
8/6/2024 4
fv* = = 103.85 psi
 fv* = 103.85 psi < Fvx' = 265.00 psi  (CSI = 0.39)   ➜  OK
fv = = 118.64 psi
 fv = 118.64 psi < Fvx' = 265.00 psi  (CSI = 0.45)   ➜  OK
8/6/2024 5
ΔLL = = 0.11 in.
(L/d)LL = 192.50 / 0.11 = 1716
 ΔLL = 0.11 in = L/1716 < L/360   ➜  OK
ΔTL = = 0.68 in.
(L/d)TL = 192.50 / 0.68 = 283
 ΔTL = 0.68 in = L/283 < L/240   ➜  OK
fc⊥ = = 177.5 psi
 fc⊥ = 177.5 psi < Fc⊥x' = 650.00 psi  (CSI = 0.27)   ➜  OK
8/6/2024 6
