Size: 4 x 6
Design Span (L): 5.75 ft.
Clear Span: 5.50 ft.
Total Span: 6.00 ft.
Live Load: 100 lbs
Dead Load: 75 lbs
Selfweight: 26.3 lbs
Dist. Selfweight: 4.57 plf
Total Weight: 27.4 lbs
Beam Design 2024A330
8/1/2024 1
8/1/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [19.25 x (69.00 + 3)] x (12 in./ft.)3 = 0.80 ft3
Volumespan = N[A x L] = 1 x [19.25 x 69.00] x (12 in./ft.)3 = 0.77 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.80 = 27.4 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.77 = 26.3 lbs
100 lbs
75 lbs
ws = 4.57 plf
5.75 ft.
5.50 ft.
101.22 lbs
101.22 lbs
8/1/2024 3
fb = = 183.9 psi
 fb = 183.9 psi < Fbx' = 1345.5 psi  (CSI = 0.14)   ➜  OK
8/1/2024 4
fv* = = 7.68 psi
 fv* = 7.68 psi < Fvx' = 207.00 psi  (CSI = 0.04)   ➜  OK
fv = = 7.84 psi
 fv = 7.84 psi < Fvx' = 207.00 psi  (CSI = 0.04)   ➜  OK
8/1/2024 5
ΔLL =   =   = 0.01 in.
(L/d)LL = 69.00 / 0.01 = 7828
 ΔLL = 0.01 in = L/7828 < L/360   ➜  OK
ΔTL =   =   = 0.02 in.
(L/d)TL = 69.00 / 0.02 = 4089
 ΔTL = 0.02 in = L/4089 < L/240   ➜  OK
fc⊥ = = 9.6 psi
 fc⊥ = 9.6 psi < Fc⊥x' = 625.00 psi  (CSI = 0.02)   ➜  OK
8/1/2024 6
