Species: Redwood
Grade: RW CS
Design Span (L): 15.25 ft.
Clear Span: 15.00 ft.
Total Span: 15.50 ft.
Live Load: 20 plf
Dead Load: 140 plf
Selfweight: 108.6 lbs
Dist. Selfweight: 7.12 plf
Total Weight: 110.4 lbs
Beam Design 2024A327
7/31/2024 1
RW CS 1750 1000 160 650 1850 1400000 510000 0.44
G = 0.44
7/31/2024 2
= 30.39 lbs/ft3
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (183.00 + 3)] x (12 in./ft.)3 = 3.63 ft3
Volumespan = N[A x L] = 2 x [16.88 x 183.00] x (12 in./ft.)3 = 3.57 ft3
Total Weight (WT) = ρw x Volumetotal = 30.39 x 3.63 = 110.4 lbs
Self Weight (WS) = ρw x Volumespan = 30.39 x 3.57 = 108.6 lbs
Distributed Self Weight (ws) = = 7.12 plf
20 plf
140 plf
ws = 7.12 plf
15.25 ft.
15.00 ft.
15.50 ft.
1295.19 lbs
1295.19 lbs
7/31/2024 3
Fbx' = (1750)(1.15)(1)(1)(1)(1)(1)(1) = 2012.5 psi
fb = = 921.3 psi
 fb = 921.3 psi < Fbx' = 2012.5 psi  (CSI = 0.46)   ➜  OK
7/31/2024 4
Fvx' = (160)(1.15)(1)(1)(1) = 184.00 psi
fv* = = 49.67 psi
 fv* = 49.67 psi < Fvx' = 184.00 psi  (CSI = 0.27)   ➜  OK
fv = = 56.64 psi
 fv = 56.64 psi < Fvx' = 184.00 psi  (CSI = 0.31)   ➜  OK
7/31/2024 5
ΔLL = = 0.05 in.
(L/d)LL = 183.00 / 0.05 = 3747
 ΔLL = 0.05 in = L/3747 < L/360   ➜  OK
ΔTL = = 0.41 in.
(L/d)TL = 183.00 / 0.41 = 448
 ΔTL = 0.41 in = L/448 < L/240   ➜  OK
Fc⊥x' = (650)(1)(1)(1) = 650.00 psi
fc⊥ = = 143.9 psi
 fc⊥ = 143.9 psi < Fc⊥x' = 650.00 psi  (CSI = 0.22)   ➜  OK
7/31/2024 6
