Size: 5.5 x 18
Design Span (L): 17.65 ft.
Clear Span: 17.40 ft.
Total Span: 17.90 ft.
Live Load: 6933 lbs
Dead Load: 2133 lbs
Selfweight: 409.7 lbs
Dist. Selfweight: 23.21 plf
Total Weight: 415.5 lbs
CV Volume Factor 0.970b - - - - -
Beam Design 2024A324
7/31/2024 1
d = 18.000 in.
7/31/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [99.00 x (211.80 + 3)] x (12 in./ft.)3 = 12.31 ft3
Volumespan = N[A x L] = 1 x [99.00 x 211.80] x (12 in./ft.)3 = 12.13 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 12.31 = 415.5 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 12.13 = 409.7 lbs
6933 lbs
2133 lbs
  ws = 23.21 plf
17.65 ft.
17.40 ft.
17.90 ft.
4740.74 lbs
4740.74 lbs
7/31/2024 3
CV = = 0.970
CV = 0.970 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.970) = 2677.8 psi
fb = = 1652.8 psi
 fb = 1652.8 psi < Fbx' = 2677.8 psi  (CSI = 0.62)   ➜  OK
7/31/2024 4
fv* = = 71.26 psi
 fv* = 71.26 psi < Fvx' = 304.75 psi  (CSI = 0.23)   ➜  OK
fv = = 71.79 psi
 fv = 71.79 psi < Fvx' = 304.75 psi  (CSI = 0.24)   ➜  OK
7/31/2024 5
ΔLL =   =   = 0.29 in.
(L/d)LL = 211.80 / 0.29 = 743
 ΔLL = 0.29 in = L/743 < L/360   ➜  OK
ΔTL =   =   = 0.38 in.
(L/d)TL = 211.80 / 0.38 = 552
 ΔTL = 0.38 in = L/552 < L/240   ➜  OK
fc⊥ = = 287.3 psi
 fc⊥ = 287.3 psi < Fc⊥x' = 650.00 psi  (CSI = 0.44)   ➜  OK
7/31/2024 6
