Beam Design - Harris Rustic
Size: 5.5 x 12
Design Span (L): 8.75 ft.
Clear Span: 8.50 ft.
Total Span: 9.00 ft.
Live Load: 1350 plf
Dead Load: 300 plf
Selfweight: 135.4 lbs
Dist. Selfweight: 15.47 plf
Total Weight: 139.3 lbs
Notes: Beam Check
Beam Design Anna McCoy P24000
7/29/2024 1
7/29/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [66.00 x (105.00 + 3)] x (12 in./ft.)3 = 4.13 ft3
Volumespan = N[A x L] = 1 x [66.00 x 105.00] x (12 in./ft.)3 = 4.01 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 4.13 = 139.3 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 4.01 = 135.4 lbs
1350 plf
300 plf
  ws = 15.47 plf
8.75 ft.
8.50 ft.
9.00 ft.
7494.63 lbs
7494.63 lbs
7/29/2024 3
fb = = 1449.0 psi
 fb = 1449.0 psi < Fbx' = 2760.0 psi  (CSI = 0.53)   ➜  OK
7/29/2024 4
fv* = = 127.75 psi
 fv* = 127.75 psi < Fvx' = 304.75 psi  (CSI = 0.42)   ➜  OK
fv = = 165.60 psi
 fv = 165.60 psi < Fvx' = 304.75 psi  (CSI = 0.54)   ➜  OK
7/29/2024 5
ΔLL = = 0.12 in.
(L/d)LL = 105.00 / 0.12 = 841
 ΔLL = 0.12 in = L/841 < L/360   ➜  OK
ΔTL = = 0.15 in.
(L/d)TL = 105.00 / 0.15 = 681
 ΔTL = 0.15 in = L/681 < L/240   ➜  OK
fc⊥ = = 454.2 psi
 fc⊥ = 454.2 psi < Fc⊥x' = 650.00 psi  (CSI = 0.70)   ➜  OK
7/29/2024 6
