Beam Design - Harris Rustic
Size: 5.5 x 12
Live Load: 1350 plf
Dead Load: 300 plf
Selfweight: 181.8 lbs
Dist. Selfweight: 15.47 plf
Total Weight: 185.7 lbs
Notes: Beam Check Only
Beam Design Anna McCoy Lava Hot Springs P23000
7/29/2024 1
7/29/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [66.00 x (141.00 + 3)] x (12 in./ft.)3 = 5.50 ft3
Volumespan = N[A x L] = 1 x [66.00 x 141.00] x (12 in./ft.)3 = 5.39 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 5.50 = 185.7 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 5.39 = 181.8 lbs
1350 plf
300 plf
  ws = 15.47 plf
9992.84 lbs
9992.84 lbs
7/29/2024 3
fb = = 2612.9 psi
 fb = 2612.9 psi < Fbx' = 2760.0 psi  (CSI = 0.95)   ➜  OK
7/29/2024 4
fv* = = 184.53 psi
 fv* = 184.53 psi < Fvx' = 304.75 psi  (CSI = 0.61)   ➜  OK
fv = = 222.38 psi
 fv = 222.38 psi < Fvx' = 304.75 psi  (CSI = 0.73)   ➜  OK
7/29/2024 5
ΔLL = = 0.41 in.
(L/d)LL = 141.00 / 0.41 = 347
 ΔLL = 0.41 in = L/347 > L/360   ➜  NG
ΔTL = = 0.50 in.
(L/d)TL = 141.00 / 0.50 = 281
 ΔTL = 0.50 in = L/281 < L/240   ➜  OK
fc⊥ = = 605.6 psi
 fc⊥ = 605.6 psi < Fc⊥x' = 650.00 psi  (CSI = 0.93)   ➜  OK
7/29/2024 6
