Grade: SP No.1
Design Span (L): 19.75 ft.
Clear Span: 19.50 ft.
Total Span: 20.00 ft.
Selfweight: 71.0 lbs
Dist. Selfweight: 3.60 plf
Total Weight: 71.9 lbs
CL Beam Stability Factor 0.330 - - - - -
Beam Design 2024A318
7/28/2024 1
7/28/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (237.00 + 3)] x (12 in./ft.)3 = 1.93 ft3
Volumespan = N[A x L] = 1 x [13.88 x 237.00] x (12 in./ft.)3 = 1.90 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.93 = 71.9 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.90 = 71.0 lbs
ws = 3.60 plf
19.75 ft.
19.50 ft.
1785.97 lbs
1785.97 lbs
7/28/2024 3
lu = Unbraced Length = 19.750 ft.
lu/d = = 25.62
le = 1.63lu + 3d = 1.63(237.0) + 3(9.25) = 414.06 in. = 34.50 ft.  (NDS Table 3.3.3)
Rb = = 41.26
 Rb = 41.26 < 50   ➜  OK
7/28/2024 4
FbE = = 408.87 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1050)(1.15)(1)(1)(1)(1)(1) = 1207.50 psi
CL =   = 0.330
Fbx' = (1050)(1.15)(1)(1)(0.330)(1)(1)(1) = 399.0 psi
fb = = 4885.1 psi
 fb = 4885.1 psi > Fbx' = 399.0 psi  (CSI = 12.24)   ➜  NG
fv* = = 175.78 psi
 fv* = 175.78 psi < Fvx' = 201.25 psi  (CSI = 0.87)   ➜  OK
fv = = 190.66 psi
 fv = 190.66 psi < Fvx' = 201.25 psi  (CSI = 0.95)   ➜  OK
7/28/2024 5
ΔLL = = 2.16 in.
(L/d)LL = 237.00 / 2.16 = 110
 ΔLL = 2.16 in = L/110 > L/360   ➜  NG
ΔTL = = 3.86 in.
(L/d)TL = 237.00 / 3.86 = 61
 ΔTL = 3.86 in = L/61 > L/240   ➜  NG
fc⊥ = = 396.9 psi
 fc⊥ = 396.9 psi < Fc⊥x' = 565.00 psi  (CSI = 0.70)   ➜  OK
7/28/2024 6
