Beam Design - glb at living room
Size: 5.125 x 15
Design Span (L): 28.75 ft.
Clear Span: 28.50 ft.
Total Span: 29.00 ft.
Live Load: 102 plf
Dead Load: 102 plf
Selfweight: 518.2 lbs
Dist. Selfweight: 18.02 plf
Total Weight: 522.7 lbs
CV Volume Factor 0.948b - - - - -
Beam Design gilbert 2402
7/25/2024 1
b = 5.125 in.
d = 15.000 in.
A = 5.125 x 15.000 = 76.88 in.2
Sx = (5.125)(15.000)2/6 = 192.19 in.3
Sy = (5.125)2(15.000)/6 = 65.66 in.3
Ix = (5.125)(15.000)3/12 = 1441.41 in.4
Iy = (5.125)3(15.000)/12 = 168.26 in.4
7/25/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [76.88 x (345.00 + 3)] x (12 in./ft.)3 = 15.48 ft3
Volumespan = N[A x L] = 1 x [76.88 x 345.00] x (12 in./ft.)3 = 15.35 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 15.48 = 522.7 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 15.35 = 518.2 lbs
Distributed Self Weight (ws) = = 18.02 plf
102 plf
102 plf
  ws = 18.02 plf
28.75 ft.
28.50 ft.
29.00 ft.
3219.34 lbs
3219.34 lbs
7/25/2024 3
CV = = 0.948
CV = 0.948 < CL = 1
Fbx' = (2400)(1.00)(1)(1)(0.948) = 2274.5 psi
fb = = 1432.3 psi
 fb = 1432.3 psi < Fbx' = 2274.5 psi  (CSI = 0.63)   ➜  OK
7/25/2024 4
fv* = = 56.86 psi
 fv* = 56.86 psi < Fvx' = 265.00 psi  (CSI = 0.21)   ➜  OK
fv = = 62.27 psi
 fv = 62.27 psi < Fvx' = 265.00 psi  (CSI = 0.23)   ➜  OK
7/25/2024 5
ΔLL = = 0.60 in.
(L/d)LL = 345.00 / 0.60 = 571
 ΔLL = 0.60 in = L/571 < L/360   ➜  OK
ΔTL = = 1.32 in.
(L/d)TL = 345.00 / 1.32 = 262
 ΔTL = 1.32 in = L/262 < L/240   ➜  OK
fc⊥ = = 209.4 psi
 fc⊥ = 209.4 psi < Fc⊥x' = 650.00 psi  (CSI = 0.32)   ➜  OK
7/25/2024 6
