Beam Design - BEATY LR BEAM
Size: 3.125 x 16.5
Design Span (L): 15.75 ft.
Clear Span: 15.50 ft.
Total Span: 16.00 ft.
Live Load: 577.5 plf
Dead Load: 165 plf
Selfweight: 190.4 lbs
Dist. Selfweight: 12.09 plf
Total Weight: 193.4 lbs
Beam Design Michael Lewallen 319 NECedar St. Camas, WA 2317
7/8/2024 1
b = 3.125 in.
d = 16.500 in.
A = 3.125 x 16.500 = 51.56 in.2
Sx = (3.125)(16.500)2/6 = 141.80 in.3
Sy = (3.125)2(16.500)/6 = 26.86 in.3
Ix = (3.125)(16.500)3/12 = 1169.82 in.4
Iy = (3.125)3(16.500)/12 = 41.96 in.4
7/8/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [51.56 x (189.00 + 3)] x (12 in./ft.)3 = 5.73 ft3
Volumespan = N[A x L] = 1 x [51.56 x 189.00] x (12 in./ft.)3 = 5.64 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 5.73 = 193.4 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 5.64 = 190.4 lbs
Distributed Self Weight (ws) = = 12.09 plf
577.5 plf
165 plf
  ws = 12.09 plf
15.75 ft.
15.50 ft.
6036.71 lbs
6036.71 lbs
7/8/2024 3
fb = = 1980.1 psi
 fb = 1980.1 psi < Fbx' = 2760.0 psi  (CSI = 0.72)   ➜  OK
7/8/2024 4
fv* = = 142.69 psi
 fv* = 142.69 psi < Fvx' = 304.75 psi  (CSI = 0.47)   ➜  OK
fv = = 172.87 psi
 fv = 172.87 psi < Fvx' = 304.75 psi  (CSI = 0.57)   ➜  OK
7/8/2024 5
ΔLL = = 0.38 in.
(L/d)LL = 189.00 / 0.38 = 498
 ΔLL = 0.38 in = L/498 < L/360   ➜  OK
ΔTL = = 0.50 in.
(L/d)TL = 189.00 / 0.50 = 381
 ΔTL = 0.50 in = L/381 < L/240   ➜  OK
fc⊥ = = 643.9 psi
 fc⊥ = 643.9 psi < Fc⊥x' = 650.00 psi  (CSI = 0.99)   ➜  OK
7/8/2024 6
