Design Span (L): 5.75 ft.
Clear Span: 5.50 ft.
Total Span: 6.00 ft.
Live Load: 4500 lbs
Dead Load: 75 lbs
Selfweight: 37.9 lbs
Dist. Selfweight: 6.59 plf
Total Weight: 39.5 lbs
Beam Design 2024A3
1/5/2024 1
Beam Design 2024A3
1/5/2024 2
Volumetotal = N[A x (L + lb)] = 2 x [13.88 x (69.00 + 3)] x (12 in./ft.)3 = 1.16 ft3
Volumespan = N[A x L] = 2 x [13.88 x 69.00] x (12 in./ft.)3 = 1.11 ft3
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.11 = 37.9 lbs
4500 lbs
75 lbs
ws = 6.59 plf
5.75 ft.
5.50 ft.
2307.27 lbs
2307.27 lbs
Beam Design 2024A3
1/5/2024 3
fb = = 1852.3 psi
 fb = 1852.3 psi > Fbx' = 1138.5 psi  (CSI = 1.63)   ➜  NG
Beam Design 2024A3
1/5/2024 4
fv* = = 124.40 psi
 fv* = 124.40 psi < Fvx' = 207.00 psi  (CSI = 0.60)   ➜  OK
fv = = 124.67 psi
 fv = 124.67 psi < Fvx' = 207.00 psi  (CSI = 0.60)   ➜  OK
Beam Design 2024A3
1/5/2024 5
ΔLL =   =   = 0.10 in.
(L/d)LL = 69.00 / 0.10 = 709
 ΔLL = 0.10 in = L/709 < L/360   ➜  OK
ΔTL =   =   = 0.10 in.
(L/d)TL = 69.00 / 0.10 = 694
 ΔTL = 0.10 in = L/694 < L/240   ➜  OK
fc⊥ = = 256.4 psi
 fc⊥ = 256.4 psi < Fc⊥x' = 625.00 psi  (CSI = 0.41)   ➜  OK
Beam Design 2024A3
1/5/2024 6
