Beam Design - Beaty LR Beam
Size: 3.5 x 16.5
Design Span (L): 15.75 ft.
Clear Span: 15.50 ft.
Total Span: 16.00 ft.
Live Load: 577.5 plf
Dead Load: 165 plf
Selfweight: 213.2 lbs
Dist. Selfweight: 13.54 plf
Total Weight: 216.6 lbs
Beam Design Michael Lewallen 319 NE Cedar St 2317
7/8/2024 1
d = 16.500 in.
A = 3.500 x 16.500 = 57.75 in.2
Sx = (3.500)(16.500)2/6 = 158.81 in.3
Sy = (3.500)2(16.500)/6 = 33.69 in.3
Ix = (3.500)(16.500)3/12 = 1310.20 in.4
Iy = (3.500)3(16.500)/12 = 58.95 in.4
7/8/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [57.75 x (189.00 + 3)] x (12 in./ft.)3 = 6.42 ft3
Volumespan = N[A x L] = 1 x [57.75 x 189.00] x (12 in./ft.)3 = 6.32 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 6.42 = 216.6 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 6.32 = 213.2 lbs
577.5 plf
165 plf
  ws = 13.54 plf
15.75 ft.
15.50 ft.
6048.32 lbs
6048.32 lbs
7/8/2024 3
fb = = 1771.4 psi
 fb = 1771.4 psi < Fbx' = 2760.0 psi  (CSI = 0.64)   ➜  OK
7/8/2024 4
fv* = = 127.64 psi
 fv* = 127.64 psi < Fvx' = 304.75 psi  (CSI = 0.42)   ➜  OK
fv = = 154.64 psi
 fv = 154.64 psi < Fvx' = 304.75 psi  (CSI = 0.51)   ➜  OK
7/8/2024 5
ΔLL = = 0.34 in.
(L/d)LL = 189.00 / 0.34 = 557
 ΔLL = 0.34 in = L/557 < L/360   ➜  OK
ΔTL = = 0.44 in.
(L/d)TL = 189.00 / 0.44 = 426
 ΔTL = 0.44 in = L/426 < L/240   ➜  OK
fc⊥ = = 576.0 psi
 fc⊥ = 576.0 psi < Fc⊥x' = 650.00 psi  (CSI = 0.89)   ➜  OK
7/8/2024 6
