Beam Design - Gail
Size: 4 x 6
Design Span (L): 5.75 ft.
Clear Span: 5.50 ft.
Total Span: 6.00 ft.
Live Load: 100 lbs
Dead Load: 75 lbs
Selfweight: 27.3 lbs
Dist. Selfweight: 4.74 plf
Total Weight: 28.4 lbs
Beam Design Gonzalo torres 4.31
7/6/2024 1
7/6/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [19.25 x (69.00 + 3)] x (12 in./ft.)3 = 0.80 ft3
Volumespan = N[A x L] = 1 x [19.25 x 69.00] x (12 in./ft.)3 = 0.77 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 0.80 = 28.4 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 0.77 = 27.3 lbs
Distributed Self Weight (ws) = = 4.74 plf
100 lbs
75 lbs
ws = 4.74 plf
5.75 ft.
5.50 ft.
101.72 lbs
101.72 lbs
7/6/2024 3
Fbx' = (900)(1.15)(0.85)(1)(1)(1.3)(1)(1) = 1143.7 psi
fb = = 184.4 psi
 fb = 184.4 psi < Fbx' = 1143.7 psi  (CSI = 0.16)   ➜  OK
7/6/2024 4
fv* = = 7.71 psi
 fv* = 7.71 psi < Fvx' = 200.79 psi  (CSI = 0.04)   ➜  OK
fv = = 7.88 psi
 fv = 7.88 psi < Fvx' = 200.79 psi  (CSI = 0.04)   ➜  OK
7/6/2024 5
ΔLL =   =   = 0.01 in.
(L/d)LL = 69.00 / 0.01 = 7045
 ΔLL = 0.01 in = L/7045 < L/360   ➜  OK
ΔTL =   =   = 0.02 in.
(L/d)TL = 69.00 / 0.02 = 3669
 ΔTL = 0.02 in = L/3669 < L/240   ➜  OK
fc⊥ = = 9.7 psi
 fc⊥ = 9.7 psi < Fc⊥x' = 418.75 psi  (CSI = 0.02)   ➜  OK
7/6/2024 6
