Size: 3.5 x 19.5
Design Span (L): 19.67 ft.
Clear Span: 19.33 ft.
Total Span: 20.00 ft.
Bearing (lb): 4 in.
Live Load: 40 plf
Dead Load: 30 plf
Selfweight: 314.7 lbs
Dist. Selfweight: 16.00 plf
Total Weight: 320.0 lbs
CV Volume Factor 0.996b - - - - -
Beam Design 2024A288
7/5/2024 1
d = 19.500 in.
A = 3.500 x 19.500 = 68.25 in.2
Sx = (3.500)(19.500)2/6 = 221.81 in.3
Sy = (3.500)2(19.500)/6 = 39.81 in.3
Ix = (3.500)(19.500)3/12 = 2162.67 in.4
Iy = (3.500)3(19.500)/12 = 69.67 in.4
7/5/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [68.25 x (236.00 + 4)] x (12 in./ft.)3 = 9.48 ft3
Volumespan = N[A x L] = 1 x [68.25 x 236.00] x (12 in./ft.)3 = 9.32 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 9.48 = 320.0 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 9.32 = 314.7 lbs
Distributed Self Weight (ws) = = 16.00 plf
40 plf
30 plf
  ws = 16.00 plf
19.67 ft.
19.33 ft.
860.03 lbs
860.03 lbs
7/5/2024 3
CV = = 0.996
CV = 0.996 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.996) = 2749.4 psi
fb = = 225.0 psi
 fb = 225.0 psi < Fbx' = 2749.4 psi  (CSI = 0.08)   ➜  OK
7/5/2024 4
fv* = = 15.52 psi
 fv* = 15.52 psi < Fvx' = 304.75 psi  (CSI = 0.05)   ➜  OK
fv = = 18.59 psi
 fv = 18.59 psi < Fvx' = 304.75 psi  (CSI = 0.06)   ➜  OK
7/5/2024 5
ΔLL = = 0.03 in.
(L/d)LL = 236.00 / 0.03 = 6823
 ΔLL = 0.03 in = L/6823 < L/360   ➜  OK
ΔTL = = 0.07 in.
(L/d)TL = 236.00 / 0.07 = 3174
 ΔTL = 0.07 in = L/3174 < L/240   ➜  OK
Ab = b x lb = 3.5 x 4 = 14.00 in2
fc⊥ = = 61.4 psi
 fc⊥ = 61.4 psi < Fc⊥x' = 650.00 psi  (CSI = 0.09)   ➜  OK
7/5/2024 6
