Grade: SPF SS
Design Span (L): 10.42 ft.
Clear Span: 10.17 ft.
Total Span: 10.67 ft.
Live Load: 53.33 plf
Dead Load: 73.33 plf
Selfweight: 17.4 lbs
Dist. Selfweight: 1.67 plf
Total Weight: 17.8 lbs
Beam Design 2024A283
7/1/2024 1
7/1/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [8.25 x (125.04 + 3)] x (12 in./ft.)3 = 0.61 ft3
Volumespan = N[A x L] = 1 x [8.25 x 125.04] x (12 in./ft.)3 = 0.60 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 0.61 = 17.8 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 0.60 = 17.4 lbs
53.33 plf
73.33 plf
ws = 1.67 plf
10.42 ft.
10.17 ft.
10.67 ft.
684.62 lbs
684.62 lbs
7/1/2024 3
Fbx' = (1250)(1.15)(1)(1)(1)(1.3)(1)(1) = 1868.8 psi
fb = = 2763.6 psi
 fb = 2763.6 psi > Fbx' = 1868.8 psi  (CSI = 1.48)   ➜  NG
7/1/2024 4
fv* = = 110.87 psi
 fv* = 110.87 psi < Fvx' = 155.25 psi  (CSI = 0.71)   ➜  OK
fv = = 121.56 psi
 fv = 121.56 psi < Fvx' = 155.25 psi  (CSI = 0.78)   ➜  OK
7/1/2024 5
ΔLL = = 0.45 in.
(L/d)LL = 125.04 / 0.45 = 276
 ΔLL = 0.45 in = L/276 > L/360   ➜  NG
ΔTL = = 1.09 in.
(L/d)TL = 125.04 / 1.09 = 115
 ΔTL = 1.09 in = L/115 > L/240   ➜  NG
fc⊥ = = 152.1 psi
 fc⊥ = 152.1 psi < Fc⊥x' = 425.00 psi  (CSI = 0.36)   ➜  OK
7/1/2024 6
