Grade: DF SS
Size: 4 x 10
Design Span (L): 9.25 ft.
Clear Span: 9.00 ft.
Total Span: 9.50 ft.
Live Load: 375 plf
Dead Load: 210 plf
Selfweight: 71.1 lbs
Dist. Selfweight: 7.69 plf
Total Weight: 73.1 lbs
Load Duration: 1.60
CL Beam Stability Factor 0.949 - - - - -
Beam Design 2024A281
6/28/2024 1
6/28/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [32.38 x (111.00 + 3)] x (12 in./ft.)3 = 2.14 ft3
Volumespan = N[A x L] = 1 x [32.38 x 111.00] x (12 in./ft.)3 = 2.08 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.14 = 73.1 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.08 = 71.1 lbs
375 plf
210 plf
ws = 7.69 plf
9.25 ft.
9.00 ft.
9.50 ft.
2815.28 lbs
2815.28 lbs
6/28/2024 3
lu = Unbraced Length = 9.250 ft.
lu/d = = 12.00
le = 1.63lu + 3d = 1.63(111.0) + 3(9.25) = 208.68 in. = 17.39 ft.  (NDS Table 3.3.3)
Rb = = 12.55
 Rb = 12.55 < 50   ➜  OK
6/28/2024 4
FbE = = 5254.65 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1500)(1.60)(1)(1)(1.2)(1)(1) = 2880.00 psi
CL =   = 0.949
Fbx' = (1500)(1.60)(1)(1)(0.949)(1.2)(1)(1) = 2732.1 psi
fb = = 1524.1 psi
 fb = 1524.1 psi < Fbx' = 2732.1 psi  (CSI = 0.56)   ➜  OK
Fvx' = (180)(1.60)(1)(1)(1) = 288.00 psi
fv* = = 105.84 psi
 fv* = 105.84 psi < Fvx' = 288.00 psi  (CSI = 0.37)   ➜  OK
fv = = 127.00 psi
 fv = 127.00 psi < Fvx' = 288.00 psi  (CSI = 0.44)   ➜  OK
6/28/2024 5
ΔLL = = 0.14 in.
(L/d)LL = 111.00 / 0.14 = 788
 ΔLL = 0.14 in = L/788 < L/360   ➜  OK
ΔTL = = 0.22 in.
(L/d)TL = 111.00 / 0.22 = 499
 ΔTL = 0.22 in = L/499 < L/240   ➜  OK
fc⊥ = = 268.1 psi
 fc⊥ = 268.1 psi < Fc⊥x' = 625.00 psi  (CSI = 0.43)   ➜  OK
6/28/2024 6
