Beam Design - edge deck beam no1 check
Grade: DF No.1
Size: 4 x 12
Design Span (L): 13.25 ft.
Clear Span: 13.00 ft.
Total Span: 13.50 ft.
Live Load: 180 plf
Dead Load: 70 plf
Selfweight: 128.5 lbs
Dist. Selfweight: 9.70 plf
Total Weight: 130.9 lbs
Incised Lumber: Yes
CF Size Factor 1.1 1 - 1 - -
Beam Design 2024A280
6/26/2024 1
6/26/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [39.38 x (159.00 + 3)] x (12 in./ft.)3 = 3.69 ft3
Volumespan = N[A x L] = 1 x [39.38 x 159.00] x (12 in./ft.)3 = 3.62 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 3.69 = 130.9 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 3.62 = 128.5 lbs
Distributed Self Weight (ws) = = 9.70 plf
180 plf
70 plf
ws = 9.70 plf
13.25 ft.
13.00 ft.
13.50 ft.
1752.96 lbs
1752.96 lbs
6/26/2024 3
lu/d = = 2.13
Rb = = 6.74
 Rb = 6.74 < 50   ➜  OK
6/26/2024 4
Eminy' = Eminy(CM)(Ct)(Ci) = 620000(0.9)(1)(0.95) = 530100 psi
FbE = = 14010.19 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1000)(1.15)(1)(1)(1.1)(0.8)(1) = 1012.00 psi
CL =   = 0.996
Fbx' = (1000)(1.15)(1)(1)(0.996)(1.1)(0.8)(1) = 1008.1 psi
fb = = 926.3 psi
 fb = 926.3 psi < Fbx' = 1008.1 psi  (CSI = 0.92)   ➜  OK
fv* = = 56.27 psi
 fv* = 56.27 psi < Fvx' = 160.63 psi  (CSI = 0.35)   ➜  OK
fv = = 65.54 psi
 fv = 65.54 psi < Fvx' = 160.63 psi  (CSI = 0.41)   ➜  OK
6/26/2024 5
Ex' = Ex(CM)(Ct)(Ci) = 1700000(0.9)(1)(0.95) = 1453500 psi
ΔLL = = 0.21 in.
(L/d)LL = 159.00 / 0.21 = 769
 ΔLL = 0.21 in = L/769 < L/360   ➜  OK
ΔTL = = 0.30 in.
(L/d)TL = 159.00 / 0.30 = 533
 ΔTL = 0.30 in = L/533 < L/240   ➜  OK
fc⊥ = = 166.9 psi
 fc⊥ = 166.9 psi < Fc⊥x' = 418.75 psi  (CSI = 0.40)   ➜  OK
6/26/2024 6
