Beam Design - mid deck beam works
Grade: DF No.1
Size: 4 x 16
Design Span (L): 13.25 ft.
Clear Span: 13.00 ft.
Total Span: 13.50 ft.
Live Load: 320 plf
Dead Load: 120 plf
Selfweight: 171.3 lbs
Dist. Selfweight: 12.93 plf
Total Weight: 174.6 lbs
Incised Lumber: Yes
Beam Design 2024A277
6/26/2024 1
d = 15.000 in.
6/26/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [52.50 x (159.00 + 3)] x (12 in./ft.)3 = 4.92 ft3
Volumespan = N[A x L] = 1 x [52.50 x 159.00] x (12 in./ft.)3 = 4.83 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 4.92 = 174.6 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 4.83 = 171.3 lbs
Distributed Self Weight (ws) = = 12.93 plf
320 plf
120 plf
ws = 12.93 plf
13.25 ft.
13.00 ft.
13.50 ft.
3057.28 lbs
3057.28 lbs
6/26/2024 3
lu/d = = 1.60
Rb = = 7.78
 Rb = 7.78 < 50   ➜  OK
6/26/2024 4
Eminy' = Eminy(CM)(Ct)(Ci) = 620000(0.9)(1)(0.95) = 530100 psi
FbE = = 10507.65 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1000)(1.15)(1)(1)(1)(0.8)(1) = 920.00 psi
CL =   = 0.995
Fbx' = (1000)(1.15)(1)(1)(0.995)(1)(0.8)(1) = 915.6 psi
fb = = 908.8 psi
 fb = 908.8 psi < Fbx' = 915.6 psi  (CSI = 0.99)   ➜  OK
fv* = = 69.56 psi
 fv* = 69.56 psi < Fvx' = 160.63 psi  (CSI = 0.43)   ➜  OK
fv = = 85.73 psi
 fv = 85.73 psi < Fvx' = 160.63 psi  (CSI = 0.53)   ➜  OK
6/26/2024 5
Ex' = Ex(CM)(Ct)(Ci) = 1700000(0.9)(1)(0.95) = 1453500 psi
ΔLL = = 0.16 in.
(L/d)LL = 159.00 / 0.16 = 1025
 ΔLL = 0.16 in = L/1025 < L/360   ➜  OK
ΔTL = = 0.22 in.
(L/d)TL = 159.00 / 0.22 = 724
 ΔTL = 0.22 in = L/724 < L/240   ➜  OK
fc⊥ = = 291.2 psi
 fc⊥ = 291.2 psi < Fc⊥x' = 418.75 psi  (CSI = 0.70)   ➜  OK
6/26/2024 6
