Beam Design - front of deck beam works
Size: 4 x 14
Design Span (L): 13.25 ft.
Clear Span: 13.00 ft.
Total Span: 13.50 ft.
Live Load: 180 plf
Dead Load: 70 plf
Selfweight: 151.3 lbs
Dist. Selfweight: 11.42 plf
Total Weight: 154.2 lbs
Incised Lumber: Yes
Beam Design 2024A276
6/26/2024 1
d = 13.250 in.
6/26/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [46.38 x (159.00 + 3)] x (12 in./ft.)3 = 4.35 ft3
Volumespan = N[A x L] = 1 x [46.38 x 159.00] x (12 in./ft.)3 = 4.27 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 4.35 = 154.2 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 4.27 = 151.3 lbs
Distributed Self Weight (ws) = = 11.42 plf
180 plf
70 plf
ws = 11.42 plf
13.25 ft.
13.00 ft.
13.50 ft.
1764.60 lbs
1764.60 lbs
6/26/2024 3
lu/d = = 1.81
Rb = = 7.31
 Rb = 7.31 < 50   ➜  OK
6/26/2024 4
Eminy' = Eminy(CM)(Ct)(Ci) = 580000(0.9)(1)(0.95) = 495900 psi
FbE = = 11128.00 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (900)(1.15)(1)(1)(1)(0.8)(1) = 828.00 psi
CL =   = 0.996
Fbx' = (900)(1.15)(1)(1)(0.996)(1)(0.8)(1) = 824.7 psi
fb = = 672.2 psi
 fb = 672.2 psi < Fbx' = 824.7 psi  (CSI = 0.82)   ➜  OK
fv* = = 46.68 psi
 fv* = 46.68 psi < Fvx' = 160.63 psi  (CSI = 0.29)   ➜  OK
fv = = 56.02 psi
 fv = 56.02 psi < Fvx' = 160.63 psi  (CSI = 0.35)   ➜  OK
6/26/2024 5
ΔLL = = 0.13 in.
(L/d)LL = 159.00 / 0.13 = 1182
 ΔLL = 0.13 in = L/1182 < L/360   ➜  OK
ΔTL = = 0.20 in.
(L/d)TL = 159.00 / 0.20 = 814
 ΔTL = 0.20 in = L/814 < L/240   ➜  OK
fc⊥ = = 168.1 psi
 fc⊥ = 168.1 psi < Fc⊥x' = 418.75 psi  (CSI = 0.40)   ➜  OK
6/26/2024 6
