Beam Design - front of deck beam
Size: 4 x 10
Design Span (L): 13.25 ft.
Clear Span: 13.00 ft.
Total Span: 13.50 ft.
Live Load: 180 plf
Dead Load: 70 plf
Selfweight: 105.7 lbs
Dist. Selfweight: 7.97 plf
Total Weight: 107.6 lbs
Incised Lumber: Yes
Beam Design 2024A271
6/26/2024 1
6/26/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [32.38 x (159.00 + 3)] x (12 in./ft.)3 = 3.04 ft3
Volumespan = N[A x L] = 1 x [32.38 x 159.00] x (12 in./ft.)3 = 2.98 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 3.04 = 107.6 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 2.98 = 105.7 lbs
Distributed Self Weight (ws) = = 7.97 plf
180 plf
70 plf
ws = 7.97 plf
13.25 ft.
13.00 ft.
13.50 ft.
1741.32 lbs
1741.32 lbs
6/26/2024 3
lu/d = = 2.59
Rb = = 6.11
 Rb = 6.11 < 50   ➜  OK
6/26/2024 4
Eminy' = Eminy(CM)(Ct)(Ci) = 580000(0.9)(1)(0.95) = 495900 psi
FbE = = 15940.11 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (900)(1.15)(1)(1)(1.2)(0.8)(1) = 993.60 psi
CL =   = 0.997
Fbx' = (900)(1.15)(1)(1)(0.997)(1.2)(0.8)(1) = 990.3 psi
fb = = 1361.1 psi
 fb = 1361.1 psi > Fbx' = 990.3 psi  (CSI = 1.37)   ➜  NG
fv* = = 69.97 psi
 fv* = 69.97 psi < Fvx' = 160.63 psi  (CSI = 0.44)   ➜  OK
fv = = 79.19 psi
 fv = 79.19 psi < Fvx' = 160.63 psi  (CSI = 0.49)   ➜  OK
6/26/2024 5
ΔLL = = 0.40 in.
(L/d)LL = 159.00 / 0.40 = 402
 ΔLL = 0.40 in = L/402 < L/360   ➜  OK
ΔTL = = 0.57 in.
(L/d)TL = 159.00 / 0.57 = 281
 ΔTL = 0.57 in = L/281 < L/240   ➜  OK
fc⊥ = = 165.8 psi
 fc⊥ = 165.8 psi < Fc⊥x' = 418.75 psi  (CSI = 0.40)   ➜  OK
6/26/2024 6
