Beam Design - mid-Deck beam
Grade: DF No.1 & Btr
Size: 4 x 16
Design Span (L): 13.25 ft.
Clear Span: 13.00 ft.
Total Span: 13.50 ft.
Live Load: 320 plf
Dead Load: 120 plf
Selfweight: 171.3 lbs
Dist. Selfweight: 12.93 plf
Total Weight: 174.6 lbs
Incised Lumber: Yes
Beam Design ashland
6/25/2024 1
d = 15.000 in.
Beam Design ashland
6/25/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [52.50 x (159.00 + 3)] x (12 in./ft.)3 = 4.92 ft3
Volumespan = N[A x L] = 1 x [52.50 x 159.00] x (12 in./ft.)3 = 4.83 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 4.92 = 174.6 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 4.83 = 171.3 lbs
Distributed Self Weight (ws) = = 12.93 plf
320 plf
120 plf
ws = 12.93 plf
13.25 ft.
13.00 ft.
13.50 ft.
3057.28 lbs
3057.28 lbs
Beam Design ashland
6/25/2024 3
lu/d = = 1.60
Rb = = 7.78
 Rb = 7.78 < 50   ➜  OK
Beam Design ashland
6/25/2024 4
Eminy' = Eminy(CM)(Ct)(Ci) = 660000(0.9)(1)(0.95) = 564300 psi
FbE = = 11185.56 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1200)(1.15)(0.85)(1)(1)(0.8)(1) = 938.40 psi
CL =   = 0.995
Fbx' = (1200)(1.15)(0.85)(1)(0.995)(1)(0.8)(1) = 934.1 psi
fb = = 908.8 psi
 fb = 908.8 psi < Fbx' = 934.1 psi  (CSI = 0.97)   ➜  OK
fv* = = 69.56 psi
 fv* = 69.56 psi < Fvx' = 160.63 psi  (CSI = 0.43)   ➜  OK
fv = = 85.73 psi
 fv = 85.73 psi < Fvx' = 160.63 psi  (CSI = 0.53)   ➜  OK
Beam Design ashland
6/25/2024 5
Ex' = Ex(CM)(Ct)(Ci) = 1800000(0.9)(1)(0.95) = 1539000 psi
ΔLL = = 0.15 in.
(L/d)LL = 159.00 / 0.15 = 1085
 ΔLL = 0.15 in = L/1085 < L/360   ➜  OK
ΔTL = = 0.21 in.
(L/d)TL = 159.00 / 0.21 = 767
 ΔTL = 0.21 in = L/767 < L/240   ➜  OK
fc⊥ = = 291.2 psi
 fc⊥ = 291.2 psi < Fc⊥x' = 418.75 psi  (CSI = 0.70)   ➜  OK
Beam Design ashland
6/25/2024 6
