Beam Design - Eave beam too small
Size: 5.125 x 7.5
Design Span (L): 16.75 ft.
Clear Span: 16.50 ft.
Total Span: 17.00 ft.
Live Load: 175 plf
Dead Load: 105 plf
Selfweight: 158.6 lbs
Dist. Selfweight: 9.47 plf
Total Weight: 160.9 lbs
Lateral Support: 4' o/c
Beam Design ashland
6/25/2024 1
b = 5.125 in.
d = 7.500 in.
A = 5.125 x 7.500 = 38.44 in.2
Sx = (5.125)(7.500)2/6 = 48.05 in.3
Sy = (5.125)2(7.500)/6 = 32.83 in.3
Ix = (5.125)(7.500)3/12 = 180.18 in.4
Iy = (5.125)3(7.500)/12 = 84.13 in.4
Beam Design ashland
6/25/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [38.44 x (201.00 + 3)] x (12 in./ft.)3 = 4.54 ft3
Volumespan = N[A x L] = 1 x [38.44 x 201.00] x (12 in./ft.)3 = 4.47 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 4.54 = 160.9 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 4.47 = 158.6 lbs
Distributed Self Weight (ws) = = 9.47 plf
175 plf
105 plf
  ws = 9.47 plf
16.75 ft.
16.50 ft.
17.00 ft.
2460.47 lbs
2460.47 lbs
Beam Design ashland
6/25/2024 3
lu = Unbraced Length = 4 ft.
lu/d = = 6.40
Rb = = 5.31
 Rb = 5.31 < 50   ➜  OK
Beam Design ashland
6/25/2024 4
FbE = = 30092.84 psi
CL =   = 0.996
CL = 0.996 < CV = 1.0
Fbx' = (2400)(1.15)(0.8)(1)(0.996) = 2199.3 psi
fb = = 2535.4 psi
 fb = 2535.4 psi > Fbx' = 2199.3 psi  (CSI = 1.15)   ➜  NG
fv* = = 87.55 psi
Beam Design ashland
6/25/2024 5
 fv* = 87.55 psi < Fvx' = 266.66 psi  (CSI = 0.33)   ➜  OK
fv = = 94.61 psi
 fv = 94.61 psi < Fvx' = 266.66 psi  (CSI = 0.35)   ➜  OK
ΔLL = = 1.15 in.
(L/d)LL = 201.00 / 1.15 = 175
 ΔLL = 1.15 in = L/175 > L/360   ➜  NG
ΔTL = = 1.90 in.
(L/d)TL = 201.00 / 1.90 = 106
 ΔTL = 1.90 in = L/106 > L/240   ➜  NG
Beam Design ashland
6/25/2024 6
fc⊥ = = 160.0 psi
 fc⊥ = 160.0 psi < Fc⊥x' = 344.50 psi  (CSI = 0.46)   ➜  OK
Beam Design ashland
6/25/2024 7
