Beam Design - Eave beam
Size: 5.125 x 10.5
Design Span (L): 16.75 ft.
Clear Span: 16.50 ft.
Total Span: 17.00 ft.
Live Load: 175 plf
Dead Load: 105 plf
Selfweight: 222.0 lbs
Dist. Selfweight: 13.25 plf
Total Weight: 225.3 lbs
Lateral Support: 4' o/c
Beam Design ashland
6/25/2024 1
b = 5.125 in.
d = 10.500 in.
A = 5.125 x 10.500 = 53.81 in.2
Sx = (5.125)(10.500)2/6 = 94.17 in.3
Sy = (5.125)2(10.500)/6 = 45.96 in.3
Ix = (5.125)(10.500)3/12 = 494.40 in.4
Iy = (5.125)3(10.500)/12 = 117.78 in.4
Beam Design ashland
6/25/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [53.81 x (201.00 + 3)] x (12 in./ft.)3 = 6.35 ft3
Volumespan = N[A x L] = 1 x [53.81 x 201.00] x (12 in./ft.)3 = 6.26 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 6.35 = 225.3 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 6.26 = 222.0 lbs
Distributed Self Weight (ws) = = 13.25 plf
175 plf
105 plf
  ws = 13.25 plf
16.75 ft.
16.50 ft.
17.00 ft.
2492.66 lbs
2492.66 lbs
Beam Design ashland
6/25/2024 3
lu = Unbraced Length = 4 ft.
lu/d = = 4.57
Rb = = 6.29
 Rb = 6.29 < 50   ➜  OK
Beam Design ashland
6/25/2024 4
FbE = = 21494.89 psi
CL =   = 0.994
CL = 0.994 < CV = 1.0
Fbx' = (2400)(1.15)(0.8)(1)(0.994) = 2195.5 psi
fb = = 1310.5 psi
 fb = 1310.5 psi < Fbx' = 2195.5 psi  (CSI = 0.60)   ➜  OK
fv* = = 61.31 psi
Beam Design ashland
6/25/2024 5
 fv* = 61.31 psi < Fvx' = 266.66 psi  (CSI = 0.23)   ➜  OK
fv = = 68.46 psi
 fv = 68.46 psi < Fvx' = 266.66 psi  (CSI = 0.26)   ➜  OK
ΔLL = = 0.42 in.
(L/d)LL = 201.00 / 0.42 = 481
 ΔLL = 0.42 in = L/481 < L/360   ➜  OK
ΔTL = = 0.70 in.
(L/d)TL = 201.00 / 0.70 = 287
 ΔTL = 0.70 in = L/287 < L/240   ➜  OK
Beam Design ashland
6/25/2024 6
fc⊥ = = 162.1 psi
 fc⊥ = 162.1 psi < Fc⊥x' = 344.50 psi  (CSI = 0.47)   ➜  OK
Beam Design ashland
6/25/2024 7
