Beam Design - ridge post support beam
Size: 5.5 x 16.5
Design Span (L): 26.58 ft.
Clear Span: 26.17 ft.
Total Span: 27.00 ft.
Bearing (lb): 5 in.
Live Load: 2873 lbs
Dead Load: 1726 lbs
Selfweight: 594.2 lbs
Dist. Selfweight: 22.35 plf
Total Weight: 603.5 lbs
CL Beam Stability Factor 0.920 - - - - -
CV Volume Factor 0.939b - - - - -
Beam Design ashland
6/25/2024 1
d = 16.500 in.
Beam Design ashland
6/25/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [90.75 x (319.00 + 5)] x (12 in./ft.)3 = 17.02 ft3
Volumespan = N[A x L] = 1 x [90.75 x 319.00] x (12 in./ft.)3 = 16.75 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 17.02 = 603.5 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 16.75 = 594.2 lbs
Distributed Self Weight (ws) = = 22.35 plf
2873 lbs
1726 lbs
  ws = 22.35 plf
26.58 ft.
26.17 ft.
27.00 ft.
2601.24 lbs
2601.24 lbs
Beam Design ashland
6/25/2024 3
lu = Unbraced Length = 26.583 ft.
lu/d = = 19.33
le = 1.37lu + 3d = 1.37(319.0) + 3(16.5) = 486.52 in. = 40.54 ft.  (NDS Table 3.3.3)
Rb = = 16.29
 Rb = 16.29 < 50   ➜  OK
Beam Design ashland
6/25/2024 4
FbE = = 3201.71 psi
CL =   = 0.920
CV = = 0.939
CL = 0.920 < CV = 0.939
Fbx' = (2400)(1.15)(0.8)(1)(0.920) = 2031.6 psi
fb = = 1564.6 psi
 fb = 1564.6 psi < Fbx' = 2031.6 psi  (CSI = 0.77)   ➜  OK
fv* = = 42.41 psi
Beam Design ashland
6/25/2024 5
 fv* = 42.41 psi < Fvx' = 266.66 psi  (CSI = 0.16)   ➜  OK
fv = = 42.92 psi
 fv = 42.92 psi < Fvx' = 266.66 psi  (CSI = 0.16)   ➜  OK
ΔLL =   =   = 0.63 in.
(L/d)LL = 319.00 / 0.63 = 507
 ΔLL = 0.63 in = L/507 < L/360   ➜  OK
ΔTL =   =   = 1.09 in.
(L/d)TL = 319.00 / 1.09 = 293
 ΔTL = 1.09 in = L/293 < L/240   ➜  OK
Beam Design ashland
6/25/2024 6
Ab = b x lb = 5.5 x 5 = 27.50 in2
fc⊥ = = 94.6 psi
 fc⊥ = 94.6 psi < Fc⊥x' = 344.50 psi  (CSI = 0.27)   ➜  OK
Beam Design ashland
6/25/2024 7
