Beam Design - rafter 42 trib
Size: 3.125 x 7.5
Design Span (L): 13.25 ft.
Clear Span: 13.00 ft.
Total Span: 13.50 ft.
Live Load: 87.5 plf
Dead Load: 52.5 plf
Selfweight: 76.5 lbs
Dist. Selfweight: 5.77 plf
Total Weight: 77.9 lbs
Beam Design ashland
6/25/2024 1
b = 3.125 in.
d = 7.500 in.
A = 3.125 x 7.500 = 23.44 in.2
Sx = (3.125)(7.500)2/6 = 29.30 in.3
Sy = (3.125)2(7.500)/6 = 12.21 in.3
Ix = (3.125)(7.500)3/12 = 109.86 in.4
Iy = (3.125)3(7.500)/12 = 19.07 in.4
Beam Design ashland
6/25/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [23.44 x (159.00 + 3)] x (12 in./ft.)3 = 2.20 ft3
Volumespan = N[A x L] = 1 x [23.44 x 159.00] x (12 in./ft.)3 = 2.16 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 2.20 = 77.9 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 2.16 = 76.5 lbs
Distributed Self Weight (ws) = = 5.77 plf
87.5 plf
52.5 plf
  ws = 5.77 plf
13.25 ft.
13.00 ft.
13.50 ft.
983.97 lbs
983.97 lbs
Beam Design ashland
6/25/2024 3
fb = = 1310.3 psi
 fb = 1310.3 psi < Fbx' = 2208.0 psi  (CSI = 0.59)   ➜  OK
Beam Design ashland
6/25/2024 4
fv* = = 55.98 psi
 fv* = 55.98 psi < Fvx' = 266.66 psi  (CSI = 0.21)   ➜  OK
fv = = 61.81 psi
 fv = 61.81 psi < Fvx' = 266.66 psi  (CSI = 0.23)   ➜  OK
Beam Design ashland
6/25/2024 5
ΔLL = = 0.37 in.
(L/d)LL = 159.00 / 0.37 = 432
 ΔLL = 0.37 in = L/432 < L/360   ➜  OK
ΔTL = = 0.61 in.
(L/d)TL = 159.00 / 0.61 = 259
 ΔTL = 0.61 in = L/259 < L/240   ➜  OK
fc⊥ = = 105.0 psi
 fc⊥ = 105.0 psi < Fc⊥x' = 344.50 psi  (CSI = 0.30)   ➜  OK
Beam Design ashland
6/25/2024 6
