Beam Design - rafter
Size: 3.125 x 7.5
Design Span (L): 13.25 ft.
Clear Span: 13.00 ft.
Total Span: 13.50 ft.
Live Load: 50 plf
Dead Load: 30 plf
Selfweight: 76.5 lbs
Dist. Selfweight: 5.77 plf
Total Weight: 77.9 lbs
Beam Design ashland
6/25/2024 1
b = 3.125 in.
d = 7.500 in.
A = 3.125 x 7.500 = 23.44 in.2
Sx = (3.125)(7.500)2/6 = 29.30 in.3
Sy = (3.125)2(7.500)/6 = 12.21 in.3
Ix = (3.125)(7.500)3/12 = 109.86 in.4
Iy = (3.125)3(7.500)/12 = 19.07 in.4
Beam Design ashland
6/25/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [23.44 x (159.00 + 3)] x (12 in./ft.)3 = 2.20 ft3
Volumespan = N[A x L] = 1 x [23.44 x 159.00] x (12 in./ft.)3 = 2.16 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 2.20 = 77.9 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 2.16 = 76.5 lbs
Distributed Self Weight (ws) = = 5.77 plf
50 plf
30 plf
  ws = 5.77 plf
13.25 ft.
13.00 ft.
13.50 ft.
578.97 lbs
578.97 lbs
Beam Design ashland
6/25/2024 3
fb = = 771.0 psi
 fb = 771.0 psi < Fbx' = 2208.0 psi  (CSI = 0.35)   ➜  OK
Beam Design ashland
6/25/2024 4
fv* = = 32.94 psi
 fv* = 32.94 psi < Fvx' = 266.66 psi  (CSI = 0.12)   ➜  OK
fv = = 36.37 psi
 fv = 36.37 psi < Fvx' = 266.66 psi  (CSI = 0.14)   ➜  OK
Beam Design ashland
6/25/2024 5
ΔLL = = 0.21 in.
(L/d)LL = 159.00 / 0.21 = 755
 ΔLL = 0.21 in = L/755 < L/360   ➜  OK
ΔTL = = 0.36 in.
(L/d)TL = 159.00 / 0.36 = 440
 ΔTL = 0.36 in = L/440 < L/240   ➜  OK
fc⊥ = = 61.8 psi
 fc⊥ = 61.8 psi < Fc⊥x' = 344.50 psi  (CSI = 0.18)   ➜  OK
Beam Design ashland
6/25/2024 6
