Size: 5.125 x 9
Design Span (L): 16.75 ft.
Clear Span: 16.50 ft.
Total Span: 17.00 ft.
Live Load: 175 plf
Dead Load: 105 plf
Selfweight: 190.3 lbs
Dist. Selfweight: 11.36 plf
Total Weight: 193.1 lbs
Beam Design 2024A257
6/25/2024 1
b = 5.125 in.
d = 9.000 in.
A = 5.125 x 9.000 = 46.13 in.2
Sx = (5.125)(9.000)2/6 = 69.19 in.3
Sy = (5.125)2(9.000)/6 = 39.40 in.3
Ix = (5.125)(9.000)3/12 = 311.34 in.4
Iy = (5.125)3(9.000)/12 = 100.96 in.4
6/25/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [46.13 x (201.00 + 3)] x (12 in./ft.)3 = 5.45 ft3
Volumespan = N[A x L] = 1 x [46.13 x 201.00] x (12 in./ft.)3 = 5.37 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 5.45 = 193.1 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 5.37 = 190.3 lbs
Distributed Self Weight (ws) = = 11.36 plf
175 plf
105 plf
  ws = 11.36 plf
16.75 ft.
16.50 ft.
17.00 ft.
2476.56 lbs
2476.56 lbs
6/25/2024 3
lu/d = = 2.67
Rb = = 4.12
 Rb = 4.12 < 50   ➜  OK
6/25/2024 4
FbE = = 50154.74 psi
CL =   = 0.998
CL = 0.998 < CV = 1.0
Fbx' = (2400)(1.15)(0.8)(1)(0.998) = 2202.9 psi
fb = = 1772.2 psi
 fb = 1772.2 psi < Fbx' = 2202.9 psi  (CSI = 0.80)   ➜  OK
fv* = = 72.25 psi
6/25/2024 5
 fv* = 72.25 psi < Fvx' = 266.66 psi  (CSI = 0.27)   ➜  OK
fv = = 79.35 psi
 fv = 79.35 psi < Fvx' = 266.66 psi  (CSI = 0.30)   ➜  OK
ΔLL = = 0.66 in.
(L/d)LL = 201.00 / 0.66 = 303
 ΔLL = 0.66 in = L/303 > L/360   ➜  NG
ΔTL = = 1.11 in.
(L/d)TL = 201.00 / 1.11 = 182
 ΔTL = 1.11 in = L/182 > L/240   ➜  NG
6/25/2024 6
fc⊥ = = 161.1 psi
 fc⊥ = 161.1 psi < Fc⊥x' = 344.50 psi  (CSI = 0.47)   ➜  OK
6/25/2024 7
