Size: 5.125 x 15
Design Span (L): 16.75 ft.
Clear Span: 16.50 ft.
Total Span: 17.00 ft.
Live Load: 338 plf
Dead Load: 203 plf
Selfweight: 317.1 lbs
Dist. Selfweight: 18.93 plf
Total Weight: 321.9 lbs
Beam Design 2024A253
6/25/2024 1
b = 5.125 in.
d = 15.000 in.
A = 5.125 x 15.000 = 76.88 in.2
Sx = (5.125)(15.000)2/6 = 192.19 in.3
Sy = (5.125)2(15.000)/6 = 65.66 in.3
Ix = (5.125)(15.000)3/12 = 1441.41 in.4
Iy = (5.125)3(15.000)/12 = 168.26 in.4
6/25/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [76.88 x (201.00 + 3)] x (12 in./ft.)3 = 9.08 ft3
Volumespan = N[A x L] = 1 x [76.88 x 201.00] x (12 in./ft.)3 = 8.94 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 9.08 = 321.9 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 8.94 = 317.1 lbs
Distributed Self Weight (ws) = = 18.93 plf
338 plf
203 plf
  ws = 18.93 plf
16.75 ft.
16.50 ft.
17.00 ft.
4759.44 lbs
4759.44 lbs
6/25/2024 3
fb = = 1226.1 psi
 fb = 1226.1 psi < Fbx' = 2208.0 psi  (CSI = 0.56)   ➜  OK
6/25/2024 4
fv* = = 77.84 psi
 fv* = 77.84 psi < Fvx' = 266.66 psi  (CSI = 0.29)   ➜  OK
fv = = 91.50 psi
 fv = 91.50 psi < Fvx' = 266.66 psi  (CSI = 0.34)   ➜  OK
6/25/2024 5
ΔLL = = 0.28 in.
(L/d)LL = 201.00 / 0.28 = 726
 ΔLL = 0.28 in = L/726 < L/360   ➜  OK
ΔTL = = 0.46 in.
(L/d)TL = 201.00 / 0.46 = 438
 ΔTL = 0.46 in = L/438 < L/240   ➜  OK
fc⊥ = = 309.6 psi
 fc⊥ = 309.6 psi < Fc⊥x' = 344.50 psi  (CSI = 0.90)   ➜  OK
6/25/2024 6
