Size: 4 x 10
Design Span (L): 13.75 ft.
Clear Span: 13.50 ft.
Total Span: 14.00 ft.
Live Load: 40 plf
Dead Load: 20 plf
Selfweight: 109.6 lbs
Dist. Selfweight: 7.97 plf
Total Weight: 111.6 lbs
Incised Lumber: Yes
Beam Design 2024A252
6/25/2024 1
6/25/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [32.38 x (165.00 + 3)] x (12 in./ft.)3 = 3.15 ft3
Volumespan = N[A x L] = 1 x [32.38 x 165.00] x (12 in./ft.)3 = 3.09 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 3.15 = 111.6 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 3.09 = 109.6 lbs
Distributed Self Weight (ws) = = 7.97 plf
40 plf
20 plf
ws = 7.97 plf
13.75 ft.
13.50 ft.
475.82 lbs
475.82 lbs
6/25/2024 3
Fbx' = (900)(1.15)(1)(1)(1)(1.2)(0.8)(1) = 993.6 psi
fb = = 386.2 psi
 fb = 386.2 psi < Fbx' = 993.6 psi  (CSI = 0.39)   ➜  OK
6/25/2024 4
fv* = = 19.22 psi
 fv* = 19.22 psi < Fvx' = 160.63 psi  (CSI = 0.12)   ➜  OK
fv = = 21.65 psi
 fv = 21.65 psi < Fvx' = 160.63 psi  (CSI = 0.13)   ➜  OK
6/25/2024 5
ΔLL = = 0.10 in.
(L/d)LL = 165.00 / 0.10 = 1620
 ΔLL = 0.10 in = L/1620 < L/360   ➜  OK
ΔTL = = 0.17 in.
(L/d)TL = 165.00 / 0.17 = 953
 ΔTL = 0.17 in = L/953 < L/240   ➜  OK
fc⊥ = = 45.3 psi
 fc⊥ = 45.3 psi < Fc⊥x' = 418.75 psi  (CSI = 0.11)   ➜  OK
6/25/2024 6
