Grade: SPF No.2
Design Span (L): 12.75 ft.
Clear Span: 12.50 ft.
Total Span: 13.00 ft.
Dead Load: 60 plf
Selfweight: 87.0 lbs
Dist. Selfweight: 6.82 plf
Total Weight: 88.7 lbs
Beam Design GILL 2024A246
6/20/2024 1
6/20/2024 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (153.00 + 3)] x (12 in./ft.)3 = 3.05 ft3
Volumespan = N[A x L] = 2 x [16.88 x 153.00] x (12 in./ft.)3 = 2.99 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 3.05 = 88.7 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 2.99 = 87.0 lbs
60 plf
ws = 6.82 plf
12.75 ft.
12.50 ft.
13.00 ft.
1084.33 lbs
1084.33 lbs
6/20/2024 3
fb = = 642.8 psi
 fb = 642.8 psi < Fbx' = 1006.2 psi  (CSI = 0.64)   ➜  OK
6/20/2024 4
fv* = = 40.31 psi
 fv* = 40.31 psi < Fvx' = 155.25 psi  (CSI = 0.26)   ➜  OK
fv = = 47.27 psi
 fv = 47.27 psi < Fvx' = 155.25 psi  (CSI = 0.30)   ➜  OK
6/20/2024 5
ΔLL = = 0.12 in.
(L/d)LL = 153.00 / 0.12 = 1282
 ΔLL = 0.12 in = L/1282 < L/360   ➜  OK
ΔTL = = 0.20 in.
(L/d)TL = 153.00 / 0.20 = 769
 ΔTL = 0.20 in = L/769 < L/240   ➜  OK
fc⊥ = = 120.5 psi
 fc⊥ = 120.5 psi < Fc⊥x' = 425.00 psi  (CSI = 0.28)   ➜  OK
6/20/2024 6
