Grade: SPF SS
Design Span (L): 12.75 ft.
Clear Span: 12.50 ft.
Total Span: 13.00 ft.
Live Load: 0 plf
Dead Load: 60 plf
Selfweight: 87.0 lbs
Dist. Selfweight: 6.82 plf
Total Weight: 88.7 lbs
Beam Design 2024A245
6/20/2024 1
6/20/2024 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (153.00 + 3)] x (12 in./ft.)3 = 3.05 ft3
Volumespan = N[A x L] = 2 x [16.88 x 153.00] x (12 in./ft.)3 = 2.99 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 3.05 = 88.7 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 2.99 = 87.0 lbs
0 plf
60 plf
ws = 6.82 plf
12.75 ft.
12.50 ft.
13.00 ft.
434.33 lbs
434.33 lbs
6/20/2024 3
Fbx' = (1250)(0.9)(1)(1)(1)(1)(1)(1) = 1125.0 psi
fb = = 257.5 psi
 fb = 257.5 psi < Fbx' = 1125.0 psi  (CSI = 0.23)   ➜  OK
6/20/2024 4
Fvx' = (135)(0.9)(1)(1)(1) = 121.50 psi
fv* = = 16.15 psi
 fv* = 16.15 psi < Fvx' = 121.50 psi  (CSI = 0.13)   ➜  OK
fv = = 18.93 psi
 fv = 18.93 psi < Fvx' = 121.50 psi  (CSI = 0.16)   ➜  OK
6/20/2024 5
ΔLL = = 0.00 in.
(L/d)LL = 153.00 / 0.00 = ∞
ΔTL = = 0.07 in.
(L/d)TL = 153.00 / 0.07 = 2056
 ΔTL = 0.07 in = L/2056 < L/240   ➜  OK
fc⊥ = = 48.3 psi
 fc⊥ = 48.3 psi < Fc⊥x' = 425.00 psi  (CSI = 0.11)   ➜  OK
6/20/2024 6
