Design Span (L): 11.50 ft.
Clear Span: 11.00 ft.
Selfweight: 37.9 lbs
Dist. Selfweight: 3.30 plf
Total Weight: 39.5 lbs
Beam Design 2024A242
6/18/2024 1
6/18/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (138.00 + 6)] x (12 in./ft.)3 = 1.16 ft3
Volumespan = N[A x L] = 1 x [13.88 x 138.00] x (12 in./ft.)3 = 1.11 ft3
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.11 = 37.9 lbs
ws = 3.30 plf
11.00 ft.
1069.77 lbs
1069.77 lbs
6/18/2024 3
fb = = 1653.5 psi
 fb = 1653.5 psi > Fbx' = 1138.5 psi  (CSI = 1.45)   ➜  NG
6/18/2024 4
fv* = = 95.97 psi
 fv* = 95.97 psi < Fvx' = 207.00 psi  (CSI = 0.46)   ➜  OK
fv = = 110.83 psi
 fv = 110.83 psi < Fvx' = 207.00 psi  (CSI = 0.54)   ➜  OK
6/18/2024 5
ΔLL = = 0.25 in.
(L/d)LL = 138.00 / 0.25 = 555
 ΔLL = 0.25 in = L/555 < L/360   ➜  OK
ΔTL = = 0.44 in.
(L/d)TL = 138.00 / 0.44 = 311
 ΔTL = 0.44 in = L/311 < L/240   ➜  OK
fc⊥ = = 118.9 psi
 fc⊥ = 118.9 psi < Fc⊥x' = 625.00 psi  (CSI = 0.19)   ➜  OK
6/18/2024 6
