Design Span (L): 12.75 ft.
Clear Span: 12.50 ft.
Total Span: 13.00 ft.
Selfweight: 111.6 lbs
Dist. Selfweight: 8.75 plf
Total Weight: 113.7 lbs
Beam Design Bolton Deck 2024A240
6/18/2024 1
6/18/2024 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (153.00 + 3)] x (12 in./ft.)3 = 3.05 ft3
Volumespan = N[A x L] = 2 x [16.88 x 153.00] x (12 in./ft.)3 = 2.99 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 3.05 = 113.7 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 2.99 = 111.6 lbs
ws = 8.75 plf
12.75 ft.
12.50 ft.
13.00 ft.
1194.37 lbs
1194.37 lbs
6/18/2024 3
fb = = 708.0 psi
 fb = 708.0 psi < Fbx' = 862.5 psi  (CSI = 0.82)   ➜  OK
6/18/2024 4
fv* = = 44.41 psi
 fv* = 44.41 psi < Fvx' = 201.25 psi  (CSI = 0.22)   ➜  OK
fv = = 52.06 psi
 fv = 52.06 psi < Fvx' = 201.25 psi  (CSI = 0.26)   ➜  OK
6/18/2024 5
ΔLL = = 0.12 in.
(L/d)LL = 153.00 / 0.12 = 1282
 ΔLL = 0.12 in = L/1282 < L/360   ➜  OK
ΔTL = = 0.22 in.
(L/d)TL = 153.00 / 0.22 = 698
 ΔTL = 0.22 in = L/698 < L/240   ➜  OK
fc⊥ = = 132.7 psi
 fc⊥ = 132.7 psi < Fc⊥x' = 565.00 psi  (CSI = 0.23)   ➜  OK
6/18/2024 6
